FiiO X7 Mk II 2GB RAM + 64GB ROM + ESS9028 PRO + Balanced + DSD + BT 4.1 aptX + Dual mSD + Dual Band WiFi + Opt Out
Discussion in 'Portable Source Gear' started by superuser1, Jul 6, 2017.
304 305 306 307 308 309 310 311 312 313
315 316 317 318 319 320 321 322 323 324
  1. JaviAl
    My new Fiio CL06 USB Cable with OTG on BOTH sides: USB-C To Micro USB and Micro USB to USB-C:
    Years searching for a cable like this since my Fiio F7 (First Gen).
  2. Brooko Contributor
    Bought it on the forums. I believe it was a Headphone Lounge cable. Photo below:
    [​IMG]
  3. Hoffmann420
    Hi.Can Someone give me first 1.0 iso image for firmware tool ?
  4. Chris J
    Placebo Brooko, placebo!
    Oh man, am I funny!
    ExpatinJapan likes this.
  5. Jim Bobber
    Hey Brooko, thanks, I seem to be gravitating to the HD800’s despite having a good 30 or 40 mins comparing them to the Focal Clears. I’ve ordered an XLR-4 to 2,5mm balanced adapter even though I’ve not made the decision yet! Can I just as what kind of music you listen too, any EDM? I do listen to EDM and it one area where the Clears extra bass kick worked! Also, sorry, but what Fiio is that in the picture? Not an X7 II and from what I’ve seen of the F5 III it’s not that either, sorry just curious!
  6. koiloco
    That should be the Q5 which runs the same amp modules as X7.
    Brooko likes this.
  7. Brooko Contributor
    I have very wide and eclectic tastes when it comes to music. From Grunge and Alternative through to Classical and Opera. The EDM I listen to is more electronica, and quite often a fusion with Jazz or another Genre (eg Trip Hop). An example of the width might be anything from Little Dragon through to The Flashbulb.
    And the set-up (koilico got it) was iPhone SE to Q5 (Bluetooth) with the AM3A module,balanced to the HD800S.
  8. JukeBoxJimmy
    Is the SSD a big drain on the FIIO battery?.........................Jim
  9. Vitaly2017
    How good is that coaxial output line? I saw it had only 1.8 vrms output is it loud enouf at the dac amp or u gota crank the volume by alot. For instance in dx200 u got 3 vrms from the coax line out.
  10. Vitaly2017
    If i use coaxial output do the x7 can still use the filters modes and eq? In spotify ? On external dacs? Or it will simply output bit perfect.
  11. Paulo Abreu
    I can’t compare since I don’t own other devices with a coaxial digital output. I didn’t even know that a digital signal could vary in volume if played from two different devices to an external DAC... I could understand that difference in voltage as the ability to play thru a longer cable/connection but no more than that - excuse my ignorance.
    As my only reference I have X7 ii connected to a Questyle CMA400i desktop DAC/AMP, and it sounds great! Btw, I had to lower the default STD gain to low so much was the power to my headphones which are easy to drive anyway. So I would say X7 coaxial line out performs as specs say.
  12. Lakson
    Coaxial (electrical spdif) should be 0,5 V according to the standard. Line out could vary. Sort of desktop standard for rca line out is 2,0 V. Portable could be lower in some (most) cases.
  13. Vitaly2017
    Thanks for sharing the info. Can you change filters or eq while being in coaxial out put mode?
    I want to use spotify and also have the advantage of the player ability to apply hes features. Wile being in coax output.
    By the way i want to use the x7 2 with my hdv820 + hd800s. Rather than my gaming laptop would that improve sound?
  14. Jim Bobber
    Hey Fiio
    So USB storage mode had been working since I reset a few days ago. Today I plug it into the same PC and it's not working. The Android image stays green when I select USB storage mode. All I can see is the SD card, not the internal storage.
    Getting to be a pain. Shame I thought the reset had fixed it!
  15. Vitor Valeri
    Hi @FiiO , luckily I was able to shoot the bug. Follow the video of the bug below:
