ASpencer
- May 9, 2015
One of the keys for evaluating battery life is to make sure WiFi is switched off.
Btw, this gave me an idea. So far I had it in Android Mode when I noticed a rather fast idle drain. Will switch to pure music mode and let it idle overnight to see if it makes any difference, hoping that in pure music mode a lot of other android processes are being suspended.
Thanks that worked. I had it in the Pure Music Mode. Got it updated.
we are taking some video about how to use X7 cause some features may not be familar with customers. hope it work and help people.
Loaded Neutron player tonight (thanks Joe)
It works well - and seems to add "something" to the sonics compared to the default app.
It works well - and seems to add "something" to the sonics compared to the default app. At a guess I'd say there is maybe a subtle crossfeed difference. Anyway - now I'd say the X7 equals the L5 Pro on sonics, and definitely kills it on usability. And that's nothing against the default app either - which I personally find easy to use and sounding really good - despite some of its quirks with library management.
And if anyone has the review X7, and is getting a little frustrated with selecting Artist > Album, and finding your tracks out of order, or lumped together (if you have multiple albums), then Neutron is a definite fix.
Strange, I just returned from TAVES, and I was told by FiiO's Canadian importer rep that the X7 will cost between $8-900 CDN, possibly more, when released, which is now scheduled to be in the new year and not before Christmas.
UK Pre Order is live
http://www.custom-cable.co.uk/fiio-x7-portable-player.html
Not sure if it was mentioned before, but if you are listening to a song and you turn off the the X7, does the DAP remember this song and take you back to it or does it go to the main menu? I hate that about the X1.
I personally don't think X7 (w/new fw) sounds on exactly the same level as L5 Pro, but the gap is closing in! And with new amp modules - the sky's the limit![]()
