Customizable like this?
The custom theme tool for the X5 (and X3, X1) is very easy to use and can really change the feel of the device. Mind you the FW on the current devices is all proprietary from FiiO and, with all due respect, super simple. I've never used Android so I really don't know.
basically, android is not that customizable in the same way... you can write a separate laucher, but it takes a lot of time, or you can use a launcher and do a theme for it.
on the other hand, android is the most customizable platform out there, so if you want to do something and have patience, everything and anything can actually be done in android. but android is almost the most complicated, and needs code writting some times for doing more complex themes... it depends on the launcher.
it is a very long story, unless very very very heavily modified, android accepts most launchers, you can experiment themes by buying the cheapest android phone you can fiind and doing themes for a particular launcher..
a launcher is an application envoirment. basically, like how x5's firmware that permits editing is. If you stay in that launcher, what you can do is the same, like x5, you can do a lot, but until a certain degree. if you re-write launcher, you can do much much more, but it takes time, and linux and android knowledge. if x7 will accept different launchers. basically, in android themes are simple, after you get to a point where you write for the launcher that is in the android at the moment.
anyways, i know your themes for x5, and they look great! With a few work, and some resizing[maybe] you should be able to port them to x7.
keep up the great work!
