FiiO X7 | DXD | DSD | 384K/64B | ESS9018+ Android | WiFi | Bluetooth | 4 AMP modules | Balanced Out |
Mar 27, 2015 at 10:23 PM Post #3,106 of 18,020
  basically, android is not that customizable in the same way... you can write a separate laucher, but it takes a lot of time, or you can use a launcher and do a theme for it.
on the other hand, android is the most customizable platform out there, so if you want to do something and have patience, everything and anything can actually be done in android. but android is almost the most complicated, and needs code writting some times for doing more complex themes... it depends on the launcher.
it is a very long story, unless very very very heavily modified, android accepts most launchers, you can experiment themes by buying the cheapest android phone you can fiind and doing themes for a particular launcher..
a launcher is an application envoirment. basically, like how x5's firmware that permits editing is. If you stay in that launcher, what you can do is the same, like x5, you can do a lot, but until a certain degree. if you re-write launcher, you can do much much more, but it takes time, and linux and android knowledge. if x7 will accept different launchers. basically, in android themes are simple, after you get to a point where you write for the launcher that is in the android at the moment.
anyways, i know your themes for x5, and they look great! With a few work, and some resizing[maybe] you should be able to port them to x7.
keep up the great work!
The UV theme is on our plan. basiclly , if you touch the center of the now playing. the screen will change from  cover display--lyric display --Tags information---UV----cover display.
Mar 27, 2015 at 10:39 PM Post #3,107 of 18,020
Thanks James. Will have to purchase to see how customizable it is. :wink_face:
Mar 28, 2015 at 5:52 AM Post #3,108 of 18,020
thanks!
i think that it would be an awesome feature!
i think that all of us really appreciate all the work that is being put in the device!
Mar 29, 2015 at 8:05 AM Post #3,112 of 18,020
  Should be the final design ( to the full UI ) of the music play App in our X7
Looks very good. Favourites shortcut, etc. Really good.
Is it possible to set which playlist it goes to when clicking "heart" (favs)?
Maybe it will be better than rockbox... :) nice!
Any chance to make it opensource? You could benefit from it :wink:
Mar 29, 2015 at 8:18 AM Post #3,115 of 18,020
willyvlyminck, well before December. More like the end of summer.
Mar 29, 2015 at 8:57 AM Post #3,118 of 18,020
Looks good, but a bit overloaded. Too many buttons and actions.
I know the target of fiio, but I would recommend an "easy mode" with just the basics.
Mar 29, 2015 at 9:08 AM Post #3,120 of 18,020
What you mean by easy? I can't think of any more easy to use as an iPod Touch, no matter the bells and Whistles. But ok, the main focus should be the music and sound, only how much better can it get than the X5, if you use decent recorded music and high quality cans?
