Dobrescu George
Reviewer: AudiophileHeaven
Will update as soon as possible. I'll also work on getting all my X5 firmwares up to its new firmware 2.6.
How good is the 2.6 for the first? I mean, does it do anything else than 1.2 does for X5II?
My RELIC theme pack for the X5ii has been updated to the official FW1.2. Grab it Here or in the second post of this thread:
https://www.dropbox.com/sh/x3227975s3urtb1/AAC-iE91nxzrb7yXAwqaVRMka?dl=0
Enjoy!![]()
Enjoy!![]()
That's just great! I'm enjoying your customized themes everyday.
Hope you will find the energy to continue developing themes for the X7 as well, if it is customizable of course...
Thanks anyway.
[left] Hello, I am new to the forum. It is possible to increase the decibels of the equalizer fiio x5 II through the modification of the firmware? up to 6 dB to 12 dB ? I can help with that? Thank you[/left]
Code:[left] Hello, I am new to the forum. It is possible to increase the decibels of the equalizer fiio x5 II through the modification of the firmware? up to 6 dB to 12 dB ? I can help with that? Thank you[/left]
Code:[left] Hello, I am new to the forum. It is possible to increase the decibels of the equalizer fiio x5 II through the modification of the firmware? up to 6 dB to 12 dB ? I can help with that? Thank you [/left]
Enjoy!![]()
I've installed x RELIC x's 1.2FW on my X5II and started updating the media library manually on Tuesday afternoon.
48 hours later the media library is still updating and the count is over 27,000.
I have two 64GB cards full of FLAC files in my X5II and am confident that I don't have 27,000 tracks!
Should I stop the update or should I wait until it completes?
I don't wait to compromise the integrity of my X5 II's FLAC file library.
Thank You!
Thank You!
Thank you for the update everyone!
The update is still going!
67 hours since starting the update, the count is at 43108.
hehehe
I have the X5 plugged into an AC adapter with the screen off and I haven't used my X5 II do to the Thanksgiving Holiday.
I don't mind letting the count run as I likely won't use my X5 again until Monday. Let's see if the count gets up to 75,000!!
I'm on a Windows 7 machine, and the 2 64GB cards I've been using in my X5 have been exclusively used for FLAC files, so I don't believe there are any hidden files on there.
On the bright side, I just ordered two 128GB MicroSD for cards (Black Friday deals) and will load the contents of both 64GB cards onto one 128GB cards (pulling the same albums from my hard drive).
I'll then re-purpose my 64GB cards.
Hopefully this will resolve the issue.![]()
