Fiio X5 3rd gen || 2x AKM 4490 || Balanced Out || DSD || DXD | DTS | Android || Dual Card Slot
post-14747913
Post #14,372 of 15,648
HungryPanda
Kent, UK
Kent, UK
I had to scan each card several times
post-14747953
Post #14,373 of 15,648
spanner43
Corbett Oregon US
Corbett Oregon US
Age
68
With the Old fiio player i was able to put my foobar Mu38 playlists files on my sd card, view and play them in folder view, there was also an option to import them to a fiio playlist that you could name. So far I can not view my mu38 playlists in the New fiio player nor do i see an option to import. Am i missing something? I hope this can still be done
post-14748085
Post #14,374 of 15,648
FiiO
Sponsor: FiiO
Guangzhou,China
Guangzhou,China
Age
13
Website
www.fiio.com
Dear friend,
Yes. :frowning2: Will fix it in next version. You may use the old version currently if this playlist function is necessary for you. Sorry for bringing inconvenience to you.
Best regards
https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com
Reactions: spanner43
post-14748214
Post #14,375 of 15,648
kakkun
Thank you WitzyZed and battosai!. I was able to get the OTA to work.
I've been wondering. How can I check which version of the kernel I have currently installed?
post-14748318
Post #14,376 of 15,648
MinnieOne
Early impressions of new Music App - Sorting of album names is finally fixed. DLNA which I never used previously crashes the app and also crashed my Win10 computer which rarely crashes at all. Don't know if it is a Windows or a FIIO issue.
post-14748352
Post #14,377 of 15,648
rustyvinyl
No viper for new update?
I'm holding my horses.....
post-14748370
Post #14,378 of 15,648
Bray90820
Is there a way to disable the swipe actions. before the update I used pi controls and would like to use them again
post-14748372
Post #14,379 of 15,648
WitzyZed
Forest Park, IL
Forest Park, IL
Settings App, Display, check "Enable Bottom Navigation Bar"
Reactions: Bray90820
post-14748433
Post #14,380 of 15,648
jkbuha
thanks for the respon,
actually it is now solved with FW 1.2.2.
this is what I do :
1. I'm on fidelizer 1.2.1 with custom kernel 2.1
2. Go back to stock recovery with AndroidTool (choose no. 3 only)
3. Install update 1.2.2 via ota
4. Install twrp+custom kernel 2.4 (follow page 956 instruction no. 1)
5. done
Yes correct - glad you could solve it!
You could also push the stock recovery IMG to sdcard, and flash the IMG via TWRP to the recovery partition, reboot and get the OTA, install and reboot, reflash kernel+TWRP.
post-14748531
Post #14,381 of 15,648
Sound Eq
i was wondering would any of newer daps from fiio sound better than fiio x5iii, excluding fiio x7
post-14748593
Post #14,382 of 15,648
chucky27
some useful (hopefully to someone) info to stop FiiO logging into the sdcard/FiiOLog/ on every boot and during runtime.
Here are the scripts responsible:
/system/bin/get_battery_data
/system/bin/get_battery_log
/system/bin/get_log
to disable logging you have to comment out the code inside those scripts (haven't try deleting the files, probably would also work).
system access required.
Reactions: jkbuha and WitzyZed
post-14748604
Post #14,383 of 15,648
jkbuha
Thanks. I've incorporated disabling of these logfiles in my next update, which will be released in the coming days.
Reactions: WitzyZed
post-14748694
Post #14,384 of 15,648
Ghost Of Lundy
Barboursville
Barboursville
I just wanted to say thanks for doing the kernal. I was about to give up on this DAP as it does have the best sound at least for me but it was so hard to use due to crashes and lags
Your kernal made it more usable
Donation incoming
Reactions: WitzyZed
post-14748744
Post #14,385 of 15,648
jkbuha
Thanks - that is much appreciated. Until recently I was planning to use the donation money towards a new player, but seeing that quite a handful of (significantly more expensive) new players in the market use the AKM 4490, it got me thinking that we should work on optimising the X5iii to the fullest. I had previously collaborated on the rockbox project for the iPod Classic for a good number of years (with the Wolfson, now that was a good DAC), so it makes sense to push this player to peak kernel and ROM before we move onto something else.
A couple of very important features are coming with the next update - a new CPU governor thats vastly superior to anything I've seen on this player before, as well as a way of removing all the logfiles that have cluttered up on the player so far. Stay tuned!
Users Who Are Viewing This Thread (Users: 0, Guests: 5)
