Kerouac
coaxl to what? Mojo? Amp ?
On the pic it looks like it might fit the Hugo (as well) => you can try
True, will try it on the Hugo 2.On the pic it looks like it might fit the Hugo (as well) => you can try
so thin common looking end to X5III and old looking RCA end to say the Hugo?It's a TRRS 3.5mm digital coaxial from the X5iii to RCA coaxial adaptor for an RCA coaxial cable to your DAC of choice that has a coaxial RCA input. No connection to an amp.
Mojo, as you know, needs a 3.5mm TS coaxial input. The tricky part is that the FiiO DAPs share coaxial with the line-out so you need to use the 3.5 TRRS to RCA adaptor, to an RCA cable, to another adaptor that's a RCA to 3.5mm TS coaxial, or you need a custom cable to connect to the Mojo.
Personally, I'm not a fan at all of the shared port as it makes it much more complex, or expensive, than it needs to be to connect to portable DACs with a TS 3.5mm coaxial input. FYI, the second Ring is the shared ground with the line-out and the Sleeve is the signal for coaxial.
Cool, thxs bro.3.5mm TRRS plug (thin common looking thing) to the X5iii. The female end of the adaptor to a male RCA coaxial cable to the Hugo.
Cool, thxs bro.
I finally got the X5iii working as DAP with the Chinese FW update. NOw trying the X5iii USB OTG to AK380
How is the battery from 100% to 10%?
You mean chinese and english updates are different?? All the best with the AK380!!
thanks !Fiio uses a specific 3.5mm coax "wiring", so you need this adapter piece to couple it to your coax cable and then to the device you want it to connect to, such as a desktop DAC, Hugo, Mojo, etc...
Coax never goes to an amp, it's a digital signal to bypass the X5iii's DAC
I demoed it a couple of times some days ago and this pic is two hours after buying it. I didnt even look at the battery meter. I bought it mainly for the sound. Guess it comes out of the box at full charge.How is the battery from 100% to 10%?
the X5iii hasn't officially been released internationally, so the Chinese fw is a little ahead.
