Riley Beale
- Jul 9, 2016
I just want to use it a little more and then give you my input on it.
Thanks
No worries. Greatly appreciate it.
Riley
Thanks
@JamesFiiO
@FiiO-Shadow
What is the In Vehicle mode of the X5 3rd gen exactly, and how does this "special" accessory make it work?
Will the X5 plug directly into my car's USB port?
What functionality can I expect in this mode?
What won't I have when using In Vehicle?
Thanks
@FiiO-Shadow Thank you very much. I followed your instructions and got it running as USB DAC. What do you suggest I use as output.. ASIO/ WASAPI or KS?
Edit: No matter what protocol i use i really have to crank up the volume on the X5.. say above 95 on H gain. I just want to understand if that is normal.
Edit 2: It was that particular track i have that needed more power (Distant Galaxy Op. 81 - Vladimir Ashkenazy).. Other tracks that are better mastered sound fantastic on the other hand with less power.
[COLOR=444444]When vehicle engine is ignited, the X5 3rd gen will power on too. When you shutdown the engine, the X5 3rd will stop playing and power off. If the Resume mode is turned on, it will play songs directly after the car starts. [/COLOR][COLOR=444444]
[/COLOR][COLOR=444444]If you want to listen to music on the car with X5 3rd gen , it's suggested to connect the X5 3rd gen to the speakers on the car with a 3.5mm audio cable. The default output mode is Line Out under In-Vehicle mode.[/COLOR][COLOR=444444]
[/COLOR]
The ASIO/WASAPI/KS are using different audio channels. If you cannot hear the difference among them, you may try to choose ASIO, which generally should have less latency.
As for the volume, did you connect through Headphone port or Line Out? And is it the same when you directly play the songs on the X5?
Will red color version be released globally as well as other colors?
I asked the same question a week ago. The answer is yes red will be available globally.
Cheers
Riley
Thank you Riley Will it be the same date as others?
I do not know for sure, but I would guess it will be ready for global distribution when the other colors are I would guess. I do not know if the red color is currently available in China upon initial limited release.
Thank you hope it will I looked up some Chinese retailers online but it doesn't seem to be released yet thou.. Can't wait for release
@jmills8 Do you have to crank up the volume this high even when using headphones directly with the X5III?
using an amp@jmills8
