MinnieOne
- Mar 9, 2017
I'll post a positive, the slider to fast forward is finally usable! Still don't understand why they can't prevent playback if no headphones or line output is plugged in?
I got a fail on downgrading firmware. apparently i can not install over a newer version. does this require a factory reset. hope not
How is the EQ on that Aune? Hows does it do with Android ? Holds two SD cards?Yeah I feel same way with performance of x5iii being sluggish.
Aune M1S turns on and off almost instantly.
Turn on instant. Play song right away.
Also the SE output for Aune is much more cleaner than x5iii.
I contacted fiio. The rep told me the Manager said that they will not make SE out as clean as Line out. Because people like different sounds. So they will keep SE output the way it is. I find x5iii lineout through A5 an improvement over SE output.
Aune doesn't suffer from that. Both SE and Bal are all good. I know it's unfair considering Aune has much more skill in their amps and tuning of sound.
Doesn't need EQ. very meticulously tuned and transparent. EQ would completely destroy the point of the sound signature of the device.How is the EQ on that Aune? Hows does it do with Android ? Holds two SD cards?
So its like an X5 , DX90 , OPUS 2 , AK240 ?Doesn't need EQ. very meticulously tuned and transparent. EQ would completely destroy the point of the sound signature of the device.
Buy your own headphones to color it please.
it doesn't need android. Look at how x5iii performs with android. Does the x5iii even bypass SRC properly with 3rd party apps? Did FiiO really tell the truth about it? How fast does x5iii play songs the second you press play?
can you skip songs incredibly fast? or does it take ages? Does x5iii perform smoothly and does not lag in any of the 3rd party apps?
Most importantly can you consistently say x5iii can play gapless playback?
I know I can on the aune!
About the dual sd. I'm not going to downplay it. Few DAPS carry dual sds, and X5iii is no exception.
But it does allow bluetooth and wifi which can important features for sure.
Kind of, but not as good as Opus 2 tbh. Not too sure about AK240.So its like an X5 , DX90 , OPUS 2 , AK240 ?
I've got an X7ii coming down this week, so my X5iii will be sold. If the X7ii proves as buggy, bearing in mind they should have been able to hit the ground running with all they've learnt from the X5iii, I'll send that back for a refund and forget about FiiO for future purchases.
A lot of the problem is when these units are sent out on tour, the reviewers who's reviews we trust, don't have long enough with the unit to find all these hard to find all the bugs.
My trouble is, I live on a 9 x 5 mile island between England and France with no specialist dealers, so have to go by reviews.
@FiiO , please In the next firmware to implement the function of melting songs, also called crossfade, is something basic and very important in audio players, do not let it escape. A greeting.
It does not work well in the other programs (with the poweramp that used in the mobile gives error and some hangs to me), in addition, I want to implement the program FIIO MUSIC to be able to take advantage of the maximum of the player. You may not use it, but I will and surely many more.The signal needs to be processed for that. So it won't be playing bitaccurate anymore.
If you want crossfade, you might wanna use a third party app that processes the audio signal if you don't mind.
