ronnel0918
- Oct 21, 2011
For those who own a red X5iii, what color is the leather case included? Is it black?
Dear ronnel0918,
No, the leather case for red X5III is red as well.
Best regards
And you have the headphone in the X5iii... that means something
Man, I don't see any smuges or finger prints.
Niiice!
i don't have to convince anyone
to my experience fiio x5 sound is a downgrade whether to an apple laptop headphone out, an 80$ usb dac/amp (hifime sabre 9018) or the V20 (which all sounded similar and neutral)
the X5 sound really inferior in comparison (i have to raise the volume because of the weak vocals and when i do it becomes fatiguing and definetly less clear)
im not exaggerating something is clearly wrong with the x5 (at least with my headphones)
I've been looking for something that speeds up the booting process and after a while i was testing a new configuration:
Now the device needs :
- 32 sec (incl.5-6 sec of holding power button) to load into android mode
- 40 sec to start playing music in Pure music mode (incl 3 sec where i was holding the power button)
here is guide:
navigate to system -> build.prop. Scroll down to the bottom and enter this line:
ro.config.hw_quickpoweron=true
and or if you want to stop displaying of boot animation:
debug.sf.nobootanimation=1
in my test i had both set on.
now my build file contains:
#MODS
#BOOTUP FASTER
persist.sys.shutdown.mode=hibernate
ro.config.hw_fast_dormancy=1
# Battery save
pm.sleep_mode=1
ro.ril.disable.power.collapse=0
profiler.force_disable_err_rpt=1
profiler.force_disable_ulog=1
dalvik.vm.checkjni=false
dalvik.vm.execution-mode=int:jit
ro.ril.power_collapse=1
power_supply.wakeup=enable
ro.mot.eri.losalert.delay=1000
ro.config.hw_power_saving=1
Personally, I would not root an X5 just to gain 10s start time.
40s sounds good, without rooting I'm below 50s ...
There might be other reasons to root though, but start speed could not be one ...
40s is a long time, 50s is a long time ... so, no big difference ...
Your way of reasoning is mistaken, your experience is questionable.
The reasoning is not correct because DAPs made by FiiO vary a ton from DAP to DAP. X7 sports one of the best ESS DACs in the world, while X5-3 sports one of the best AK DACs in the world. There is a known difference between ESS typical sound and Asahi Kasei typical sound, if you prefer ESS sound, you should look into X7 instead of X5-3. This is a thing of preference.
As for your experience, X5-3 is extremely clear, and its mids are sweeeet. What you might prefer is the treble of ESS, and since X5-3 sports a very smooth treble and you might like your treble on the neutral / energetic side, maybe you would like X7 + AM3 better.
This being said, this is a matter of taste and preference, X5-3 is an awesome DAP and so is X7, but they are made to satisfy different preferences and different listeners. I deeply appreciate FiiO having different signatures and satisfying different tastes![]()
. So many comments that the X5 III is warm and smooth, but I find it closer to accurate/neutral. Maybe FiiO tweaked it in the latest firmwares. 1.1.4 sounds pro, better than X7 IMO.
