nobita2712
- Apr 20, 2017
^^ Thank you. I really feel confused between Fiio X5 3rd gen & dx 80.
No worries. I would really suggest you giving them both a try first but if you don't have that luxury then I would probably just think about which features you would like to expect from a DAP and what type of sound signature you're expecting as both of them really are two different sounding DAPs.
Just my 3 centsX5 III architecture much more sophisticated (dual amps, balanced output). Taking into account constant upgrades of software, X5 III will be brilliant in the near future. By now there is no player that can beat X5 III at this price tag (or even higher).
Hi M. Petka,
Thanks for your information.
Did you use dx80?
It happened to me, glad it did no happen to you. I can ride a motorcycle without a helmet, however, I prefer to wear it.
Can your S8 drive a 300ohm headphone? These can't be identical the drive capability and tone of S8 compared to X5 III. You might be dreaming Lol
Let's be honest, many times audio players sound similar, but under closer inspection there are differences.
I've been looking for something that speeds up the booting process and after a while i was testing a new configuration:
Now the device needs :
- 32 sec (incl.5-6 sec of holding power button) to load into android mode
- 40 sec to start playing music in Pure music mode (incl 3 sec where i was holding the power button)
here is guide:
navigate to system -> build.prop. Scroll down to the bottom and enter this line:
ro.config.hw_quickpoweron=true
and or if you want to stop displaying of boot animation:
debug.sf.nobootanimation=1
in my test i had both set on.
now my build file contains:
#MODS
#BOOTUP FASTER
persist.sys.shutdown.mode=hibernate
ro.config.hw_fast_dormancy=1
# Battery save
pm.sleep_mode=1
ro.ril.disable.power.collapse=0
profiler.force_disable_err_rpt=1
profiler.force_disable_ulog=1
dalvik.vm.checkjni=false
dalvik.vm.execution-mode=int:jit
ro.ril.power_collapse=1
power_supply.wakeup=enable
ro.mot.eri.losalert.delay=1000
ro.config.hw_power_saving=1
16 bit FLAC Avicii hey brother (because it had clear vocals) even if i listen to old music FLAC music it becomes just as clear, (volume was matched but not properly, because it impossible to match the x5 exactly because its less neutral, than the laptop or the usb dac/amp
the vocals on the x5III are not detailed they sound thicker yet more congested (difference is very clear) and i find my self wanting to raise the volume and when i do it becomes fatiguing
i used to own a fiio x3 and yes i thought it sounded good with my old hd598 (but i don't have them any more), after i upgraded to the 700 and using the fiio x5 i didn't like it from the beginning thats why i ordered the V20 because i compared the laptop earlier (15" retina MacBook pro) and the laptop was clearer , so as the usb dac/amp (you really need a neutral source) and the fiio x5 is clearly worst player i had
but again I'm not an audiophile.
Maybe you need to practice reading! I specifically mentioned IEMS's, not headphones. Its obviously not going to drive demanding headphones![]()
I have both as you can see.
Man, I don't see any smuges or finger prints.
Niiice!
There might be other reasons to root though,
I've just managed to run all Viper Effects without payment![]()
Hi ctruth
I love design dx90's body.
