[FiiO M6] Portable High-Resolution Lossless Music Player,Embracing A Wireless Future
cleg
- Oct 14, 2011
I've watched a portafi review on YouTube, I like the gallery icon/feature from settings. Is that literally a gallery of album art or can the album art be chosen to play the subsequent album??
Gallery is just displaying album covers. Not really useful feature of course.
I think FiiO should consider adding such list with albums cover to player itself
greenflash
I guess it's just the standard Android gallery app will show any picture in the device
dimmockg
- Sep 10, 2007
That's a shame, would have been cool to have been able to select an album that way
zeppu08
- Jan 16, 2014
Anyone can compare the M6 vs hiby r3 pls?
ArlakTheRecluse
Just like on the good ol’ iPod.That's a shame, would have been cool to have been able to select an album that way
harry501501
IGNORE - Found answer
Unknown757890
When things are good we don’t complain. But when the slightest things are bad, we care about it much more.
harry501501
So wee update. Sound for anyone interested is not like any FIIO product I've had before... but that's only the X1 and then DACs e10k and a30. But they all had a thicker body to the sound, and heavy bass (not the most resolute).
The M6 is the opposite. With all the IEMs I've used so far I'm getting the same vibe. It has a much thinner sound, very airy, very BA like body. Sub bass extension isn't anything special, mid bass tho is very quick and gives it just enough warmth as to be smooth. Detail is very good. No harshness with any earphones I've used. Quite liking it.
USB DAC :
PRO Windows very easy to set up. Plug in and it installs driver right away. Instantly pops up in Sound as a playback device. Same sound. Good match with the AMPS I have, clean sound.
CON - M6 heats up very quickly as a DAC?
Didn't buy it for DAC though... but it does give me a different sound to my more V shaped Sabaj DA3
USB DAC :
greenflash
Interesting, I'm a bassy guy myself (every ear and taste is different), hence the only headphones i've liked are Sennheisers (always bought portable ones, I use them in the commute). Currently PX100II, bassy, loud. Love'em.
I'm using X1/X1II and they feel allright, though I use them mostly in line out mode connected to my big amp.
We'll have to see about the M6, been planning to use it in the commute instead of the phone + amp/dac, but possibilities are a lot.
USB DAC :
Good tip about the heat. Yeah not buying for the computer DAC (I have a Q1 that I use for that - runs coldest, coldest, also getting a BTR1K that can do such thing).
Will test it though!
Markf
- Aug 25, 2016
Can the M6 give out good deep bass?
harry501501
In my opinion, no. I'll try it with some of my bassier IEMs when I get a chance though.
harry501501
I'll have a listen with my Px100II to
harry501501
So tried with the PX100II and I'll say up font, it's probably the best I've heard them. The airy nature of the M6 def helps expand that soundstage and takes a bit of the thickness out of the Senn. BUT the meaty sub bass of the PX100II has 100% been toned down, less lushy (that a word?) and doesn't have the same weight. The notes are still there... I actually think it sounds better for it. Might stick with this pairing rest of the night
Backs up my initial findings that this is a more balanced sounding DAP. Airy, soft and clean, detail is very good. Although there's a lighter touch to the body it isn't lacking in impact.
greenflash
WHOOA great that you got to test them with the same headphones I have! Well to be honest some combinations I have made with the PX100II sound a little .. fatiguing, so if they take out a bit of that "muddy" thickness it's really a cool thing.
Total: 9 (members: 0, guests: 9)
