[FiiO M6] Portable High-Resolution Lossless Music Player,Embracing A Wireless Future
greenflash
It seems that "Unwanted applications can be removed"? I got this from a Polish review, and it's interesting because I don't plan on using KKBOX, NetEase, MMOV, Joox etc.. they're not even available in my country. That's positive, I thought for a while they were stuff with some kind of deal you couldn't remove. Great.
Hope someone can give me some advice. I cannot load the MPT and USB DAC drivers onto my laptop. They loaded successfully on my desktop, so something is stopping both drivers on the laptop.
The Samsung phone driver error only states 'MSS install wizard could not install Samsung USB driver'. No error report or details.
The Fiio dac driver error 'ERROR: Pre-installation of 'C:\Program Files\FiiO\FiiO_Driver\W10_x64\fiio_usbaudioks.inf' failed.
Please run setup again!'
I turned off modem, Windows firewall, and Avira virus protection, suspecting one might be blocking the files. Same result. I copied the completed files from the desktop onto the laptop, but that doesn't work. I also, copied the .inf file from the desktop to the laptop, but same result.
The supplied files themselves are fine, and the problem is isolated to my laptop. Strange that both files won't load.
Any suggestions would be great. I'm not tech savvy, so please keep it simple if you have a solution!
Cheers
Cheers
greenflash
Cheers
Did you try running the installer as administrator?
dimmockg
- Sep 10, 2007
If somebody could confirm the fiio music functionality on the M6 works as per the app I've downloaded (android phone) then I'm in - the fiio app on my phone accesses my NAS and works perfectly over DLNA
That is the hope but I would like @FiiO to confirm it none the less. Again all the more reason to buy local as I wouldn't want to mess with having to ship it to another country. I had a warranty issue with an E07K and being able to take it back to the store was such a painless experience. I have also had to ship products to China under warranty and it was a major pain every time.
As for sufficient supply I guess it all depends on how well these three DAP's sell as to how long they will have stock on the 7270 and if they will hold any back for possible warranty coverage.
I think you will not get a confirmation now which will help you in a case in future which you are affraid of. I reccomend you stay away from the device and look somewhere else. (Good luck finding a company which gives you information about their stock on spare parts)
Fiio music app on M6 have a more simple UI in comparison to FiiO Music on Android Phone but seems to provide same functionality.
FiiO Link from FiiO Music app on phone to M6 allow you to remote control FiiO Music app on M6 over BT but on limit to playing local file on M6.
With FiiO Link on, I have tried to play a media on NAS via DLNA from FiiO Music on phone does result the app on M6 to do the same, the sound still come out my phone not M6.
Playing a media on NAS via DLNA from M6 itself does work but some time buggy; the FLAC 24/192 causing error file not found while doing the same on Phone work perfectly.
1. Want to confirm, FiiO Link is not available for iPhone FiiO apps yet?
2. What does the BT Control do in the FiiO iPhone apps?
Thanks.
Thanks.
Lespectraal
fish1050
I don't need to know stock levels just what Fiio plans to do when stock runs out, big difference. I don't need your recommendation I know what I am looking for and what is important to me. Warranties are not something everyone worries about but I have been buying and sold audio gear for a long time and I know the value of a warranty having had to make claims several times.
dimmockg
- Sep 10, 2007
Bit the bullet and ordered one - should arrive tomorrow
Couple of questions...
1) is anybody using a 3rd party case for the fiio M6 at all? I don't think any have been made yet but wondered if anybody had improvised
2) I have a balanced cable with 2.5 connector on the end, would I get the same benefits using this cable if i got a 2.5 trrs female to 3.5 male adapter/connector
3) in the absence of a 3rd party case for the fiio, what do people use as a dap/iem carrier - sat nav or camera pouch?
Many thanks
Many thanks
greenflash
I bought the one at: https://www.aliexpress.com/item/C-M...layer-M6-Leather-cover-Black/32963929879.html
But as someone indicated, this is a case but won't protect the front (i.e not a bag). Still didn't get, waiting till the end of february for both the DAP and the case.
So for now, as you said, I bought this sorta ugly camera pouch until something better comes along!
dimmockg
- Sep 10, 2007
Cheers for the info, I like the one on AE but like you say no screen protector.
I'll get hunting for a camera or sat nav pouch I reckon
greenflash
Of course a GPS pouch how didn't I think of it! (MP3 players cases are more rare!). Will look for one now. ThanksI'll get hunting for a camera or sat nav pouch I reckon
BetterLate
Build quality on my AP80 is excellent. It seems some have had wobbly volume wheels, and others (most?) have had no problemsIt's really sad that they couldn't get a battery capacity closer to that of the M7 with it's incredible battery life, with that the M6 would've been the definitive device. Though its true with it's small size it'd been difficult to make it fit. Who knows batteries are getting more and more efficient in the proportion of Mah/dimensions.
The build quality is really that bad? how about the battery life? 8-10h?
You should ask @FiiO @JamesFiiO, because that standby time you mention doesn't seem correct.
Total: 8 (members: 0, guests: 8)
