abitdeef
Formerly known as ihatepopupads
- Oct 30, 2003
Would this be a downgrade in terms of sound quality from a X5 3rd gen?
Honestly I would say yes.
Deown
What? Only thing that matters is how the card is formatted. A person was having trouble with the Mac software using their m6, sometimes there is driver incompatibilities, especially with macs. There still has to be a usb device driver for m6.
Nope. Both - the SanDisk and the Samsung - were FAT32 formatted. Even the FiiO Spokesguy here said if the OTA / File Update fails one should try another SD-Card.
Deown
I’m not talking about an OTA update, I’m talking about someone trying to use their m6 with a Mac and was having issues. His card was fine, it was a software problem.
I’m using a Sandisk with no problems so idk know but it’s not all card issues lol.
Thought so.
I do love the SQ of my X5 iii but the hardware is not good at all for android. very laggy and slow.
I dont want to spend £500 on HiBy R6 or IBasso DAP. So might be stuck with this unless someone magicly releases £250 DAP that sounds as good.
then the M6 is even more picky than expected. I keep my Samsung SD Card in reach for future updates... Hopefully with an Audiobook App whitelisted....
Naaaa, can not agree to that. Never had a Smartphone or PC that had Problems with either sandisk or Samsung.No more picky than any other dap, and that’s only 2 cases that I know of concerning the m6. I don’t know of any others that had problems updating.
Thought so.
FiiO M9 is a definite sound upgrade on the M6, also M9 has a powerful 2.5 mm balanced output too.
Either way, hope Batterylife will improve. Like the DAP, has a very nice Feel to it.
Wait for it. The M6 isnt broadly available.
Do You guys turn off the Device each and every time or do You Put it in "deep sleep"?
