It is not possible that it takes all evening and maybe not enough to download the M6 update !!!
And at home I have a 1Gbits fiber connection!!!
Average 50Kb / s
@FiiO
Average 50Kb / s
@FiiO
I imagined that, and I also can surely tell there won't be (and maybe shouldn't be) a browser because they're huge resources consumers (well at least Chrome). Maybe a slimmer browser..
Anyway it's not an uncommon need, a wifi that requires a browser login, seen quite a few, in hotels too..
How about this as a workaround.. Connect your phone to the browser-validated network and then set up the phone as a hotspot and connect the M6 to that hotspot? Not what you intended but should work I guess.
(Myself I'll use the M6 on the road so I plan to connect to my phone's 4G as hotspot)
oops is it the OTA update? Is there a way to do it manually (the full download)? Maybe with some download manager it might improve..It is not possible that it takes all evening and maybe not enough to download the M6 update !!!
Average 50Kb / s
@FiiO
Oh no phones. Didn't think of that. Yeah somebody suggested the ES File Explorer option. I use it in my Android phone and didn't know about that.. Brilliant!A little update. what you suggest is not possible because were not allowed to use our phone in the office. So what I did was open the ES File explorer then go to Cloud tab, then there it is, it open a tab that I can put on the log in details before opening my cloud drive.
Average 50Kb / s
@FiiO
Of course, it was the solution I was adopting.Just download it directly and put it in your SD card.
Nobody?
Hi guys.
My Fiio M6 has just arrived and I have already updated to the firmware 10.1. I am, for now, very satisfied with the purchase. The only thing I complain about is replay gain. It does not level the volume of the songs well. The volume changes often. I use FLAC files and they are all put in one folder. I use album option. Maybe I'm doing something wrong? Are you working?
Nobody?
Hi guys.
For me the replay gain function doesn’t seem to be working very well either. I find that DSD files have much lower volume than let’s say the aiff and FLAC files I have. Even when I have different files in 1 folder of album there’s alot of variance in volume.
It does not bother me too much though, but sometimes I really need to reach fort he volume control quickly.
