- Jan 30, 2011
If you haven’t tagged your files with the replaygain information, it won’t work. And replaygain IS working perfectly on my M6 and M9
Dear friend,No, unfortunately the link does not work. Instead of downloading the file, it redirects me to a blank webpage. I do appreciate your quick response!
Dear friend,I would like to verify: Does this M6 Support DLNA? If yes, is the support via an application on a smart phone, or is the M6 a standalone DLNA receiver/client/renderer?
Dear friend,need help, how do i connect to wifi with log in? its just say connected but no internet, it should prompt a username and password to connect to the internet
Only 12 left in stock.. order soon! (Amazon says so, but yeah, go for it!)does anybody know when it's going to be in stock?
Yes insert any microsd card)Just bought an M6, hooked up to wifi, and trying to do an online firmware update but keep getting a 'no TF card found' error. Do I need a microsd installed for this to work? Any help gratefully received!
