I've been trying some alternative launchers from f-droid and I found that the kiss launcher is a good fit for the m6.
[FiiO M6] Portable High-Resolution Lossless Music Player,Embracing A Wireless Future
rustyvinyl
- Jan 31, 2007
Nice. Did it eat up more ram than the stock one?
Guys, is the Fiio M6 good with headphones like the Campfire Andromeda?
Dear user,Guys, is the Fiio M6 good with headphones like the Campfire Andromeda?
Recommended headphone impedance for M6 | 16~100Ω |
And due to individual preferences, you could read the professional reviews and comparisons, as well as try out by yourself.
Best regards
inmortable
Is youtube music app still not available for m6?
superuser1
Try NewPipeIs youtube music app still not available for m6?
Claypole
Anybody else having problems with Amazon Prime Music in this device? It opens OK, starts to play a song, but within a few seconds it seems to grind to a halt, and then the M6 reboots...
RynoWeiss
- Nov 27, 2011
I got a Fiio M6 to pair with my Drop THX Panda. Running LDAC in 990kbps works fine with internal storage, but with the Wifi on, that mode is basically unusable. Nonstop stuttering. Is this normal? Is it true of the other players in Fiio's line?
Dear user,Anybody else having problems with Amazon Prime Music in this device? It opens OK, starts to play a song, but within a few seconds it seems to grind to a halt, and then the M6 reboots...
We got the feedback from a user that the 16.12.1 version Amazon music app could work fine in the M6. So you may have a try?
Best regards
Dear user,I got a Fiio M6 to pair with my Drop THX Panda. Running LDAC in 990kbps works fine with internal storage, but with the Wifi on, that mode is basically unusable. Nonstop stuttering. Is this normal? Is it true of the other players in Fiio's line?
The electromagnetic signal is too strong. The working channel of the Bluetooth signal is 2.4G, which is also the working channel of WiFi. Bluetooth and WiFi are so common on the cellphone right now. When in places like subway or shopping mall which are crowded, Bluetooth signals transmission will be severely affected by the 2.4G signals transmitted by a large number ofelectronic devices. In this case, please try to avoid using Bluetooth devices as possible. On the other hand, you can try to keep the transmitter and receiver as close as possible. For example, on the subway, you can hold your mobilephone in front of your chest.
You could try the Bluetooth playback qulity to LDAC-connection first for help.
Best regards
dharmasteve
I have no problem in general running Amazon HD. Occasionally I have to sit whilst my Internet stutters. It's OK 95% of the time. Are you running on 2.4 or 5 ghz WiFi. Maybe alternate them to see if one is better than the otherAnybody else having problems with Amazon Prime Music in this device? It opens OK, starts to play a song, but within a few seconds it seems to grind to a halt, and then the M6 reboots...
RynoWeiss
- Nov 27, 2011
Do your other devices have similar problems? Would upgrading to the M11 fix it?Dear user,
Best regards
Claypole
The M6 doesn’t support 5ghz WiFi, but it’s not the connection. The app just crashes, even offline.I have no problem in general running Amazon HD. Occasionally I have to sit whilst my Internet stutters. It's OK 95% of the time. Are you running on 2.4 or 5 ghz WiFi. Maybe alternate them to see if one is better than the other
dharmasteve
What version of Amazon HD are you using? Version 12.9.1 work well on mine. Also I've uninstalled unnecessary apps to avoid clashes or low ram. Anyway 12.9.1 is working on mine.The M6 doesn’t support 5ghz WiFi, but it’s not the connection. The app just crashes, even offline.
Claypole
I'm on version 15.19.4 of Amazon Music. I will try 12.9.1, or 16.12.1, as also advised, cheers.What version of Amazon HD are you using? Version 12.9.1 work well on mine. Also I've uninstalled unnecessary apps to avoid clashes or low ram. Anyway 12.9.1 is working on mine.
The main reason I chose the M6 is because it could run Tidal, Amazon Music, and Spotify, yet they've all now given me grief. The only thing that works ok is Fiio Music, which everybody seems to slate...
Total: 7 (members: 0, guests: 7)
