[FiiO M6] Portable High-Resolution Lossless Music Player,Embracing A Wireless Future
Jul 29, 2019 at 11:19 PM Post #2,716 of 3,610
I think this is the one I installed. Works well for me.
Thanks, I just did a factory reset, and I'm trying the version they sent me I think it's 2.11. If that doesnt work I'll try this.
Thanks ! I'm just trying the factory reset because I had to do it after the firmware update for my m11 to get neutron to work properly- it was crashing. So I figured I'd try
Jul 29, 2019 at 11:20 PM Post #2,717 of 3,610
Wonder why it works for me? Latest firmware. Installed. Worked. Files are aac256.
When I tried to install it on my Sony tablet, it reported an error stating that it was not available in my country. (USA)
Jul 29, 2019 at 11:22 PM Post #2,718 of 3,610
Oh that link isn't working for me, it only downloads like 7 megs and doesnt load. And the new one still just has static. ****ing hell it downloads like 6.9 meg as an apk and doesnt work. I have the licence, but the stupid eval ones don't let you validate them
Jul 30, 2019 at 12:08 AM Post #2,719 of 3,610
Jul 30, 2019 at 12:11 AM Post #2,721 of 3,610
Link isn't working mate. None of the new versions are working from their site either.
Works for me.. tried right now.. it automatically starts downloading the file!
Jul 30, 2019 at 12:32 AM Post #2,723 of 3,610
Nope still all static, going to try another reset and see. If not idk. But now my evaluation one that was working isn't. :frowning2: super, are you on the latest fiio firmware 1.02?
Jul 30, 2019 at 12:38 AM Post #2,724 of 3,610
Si Senor!!
Jul 30, 2019 at 12:57 AM Post #2,725 of 3,610
Si Senor!!
Nope still not working, every song sounds like an amplified waterfall. :frowning2: That version he gave you is the latest btw. I guess I should have kept the eval one that was working.
Anyways bud, thanks for the link and trying to help this olde man out :) If I can find a non eval version 2.10 I might be okay. I can email neutron tomorrow. Time for sleep for me zzzzzzzZzzzz
why's everything have to be such a pain in the ass? Lol
fiio: we whitelisted neutron, yippie!!! Ok guys, now good luck on finding a version that works. Ha ha ha
Jul 30, 2019 at 1:07 AM Post #2,726 of 3,610
Thought I downloaded 2.10. Neon +Arm7 Version and had only static on my M9. When uninstalling the app it said 2.11.??
Because of all this hassle I use poweramp for now. So far so good.
Not sure if I really „need“ neutron. Probably when I do not get poweramp validated.
Jul 30, 2019 at 4:57 AM Post #2,727 of 3,610
Jul 30, 2019 at 5:06 AM Post #2,728 of 3,610
No, it didn't, the issue is still there, although it wasn't as prominent for mine anymore. Another user reported the same.
@FiiO , I am not asking for any other features or improvement, all I am asking is that this basic feature for a MUSIC player is spotless. It's really frustrating that it has to stutter once in a while at the start of some songs...
Dear friend,
Does the issue happens in all the music files? You may send your music to support@fiio.com and we will try to reproduce the issue first. Thanks in advanced!
Best regards
Jul 30, 2019 at 5:13 AM Post #2,729 of 3,610
Seems like my shoddy work-around for installing apps isn't required anymore. Just as well, as I've since found out the apps get removed after a power cycle, and after that I've been completely unable to get it working again. Whoops!
I'm just glad PowerAmp is on the whitelist now, such a fantastic app.
Jul 30, 2019 at 6:43 AM Post #2,730 of 3,610
