cristox
- Jun 6, 2008
Do the links to the apps on the whitelist work for anybody using an Android smartphone?
Juts tried the Neutron link and it works on Chrome on my S10+.Do the links to the apps on the whitelist work for anybody using an Android smartphone?
Are these the paid versions of neutron and poweramp?
Yep guys the fiio one works and it isn't a stupid eval version. Thanks for the link
It has all the high res settings and is neon enhanced.
Sounds great
Do you mean it is the full version without paying?
Dear friend,The issue is random. Compared to the previous firmware, the issue has been improved, but it still happens. Once in a while, when I start up the app and play songs, after a few songs, there will be a quick, brief stutter at the start of a random song. After the stutter, the issue will go away, and would come back maybe about half an hour later?
Yes, neutron has a 5 day countdown, I prefer poweramp for my use. That or jetaudioYikes I'm
Idk, it's probably got a timer on it once you activate wifi
