The1Signature
dear friends,
i finally join the party
Welcome to the Tribe. That view tho… No Problems with mobile signals in that place uh?dear friends,
This is on the way. Silicon case from AliExpressAny recommendations on cases for the M17? I am not a huge fan of the case that came with it and was wondering if any of you have bought a aftermarket case for it
you don't need a mobile phone in this building here, the signal goes directly in your brain and melts itWelcome to the Tribe. That view tho… No Problems with mobile signals in that place uh?
I don't, but M17 fits perfectly in a Pelican micro 1040 case. I bought one when I first bought my M17, and it lives in there if its not being used. It feels like 1040 was made for the M17.
LMAO… that made me spit my drink.you don't need a mobile phone in this building here, the signal goes directly in your brain and melts it
true, to recap the picture, see the former post.I don't, but M17 fits perfectly in a Pelican micro 1040 case. I bought one when I first bought my M17, and it lives in there if its not being used. It feels like 1040 was made for the M17.
I'm using NMP most of time, open natively both, DSD (DSF and DFF) as well as SACD ISO.I used neutron in the past and I remember it worked ok and did read DSD properly
But yesterday I installed the free version (thinking in buying it) and the DSD files are not showing ok? Instead of 2.8M it shows 88.2k?
Am I missing something?
Bitperfect profile and native dsd must be set, then il will show 2.8MI used neutron in the past and I remember it worked ok and did read DSD properly
Well, coaxial works with Hi-Res of at lest 192KHZ (the maximum I have) but not DSD (at least, my X45 does not play them). Can anyone confirm this with their equipment. BTW, I don’t think this has anything to do with FiiO and I think that’s just the way Coaxial works.
Also, @Nomax .I am sure FiiO is now aware of the problem. No need to carry on flogging the horse.
