[FiiO M17] Dual ES9038PRO, dual THXAAA-788+, dual power supplies, 9200mAh battery, 2 volume control modes
Mar 14, 2022 at 8:19 AM Post #3,272 of 5,703
The M17 has two usb ports. And only when the connecting the USB DAC to the USB 2.0 port, the DC input could charge the M17. But currently, the USB 2.0 could not support usb output when third party APP is not in Exclusive USB Audio Access Mode. We will add the support in next firmware update at about next month.
Best regards
That's a good news, as it is actually uncomfortable when we use the M17 with Qobuz or Amazon HD and we connect an external desktop DAC + AMP.
Mar 14, 2022 at 9:05 AM Post #3,273 of 5,703
Best regards
Fabulous! This is great news! Thanks Fiio!
Mar 14, 2022 at 6:17 PM Post #3,274 of 5,703
I just purchased an M17. I’m loving the sound quality in general, but I’m having an issue with airplay mode. Lip sync with my iPad and iPhone is really bad. I also get some kind of occasional clicking noise. I only get the clicking when audio is playing. I hear nothing when it is paused. I also own an M11 Pro. I have neither of these issues with that device. Has anyone else experienced this or have a possible solution?
Mar 15, 2022 at 12:24 AM Post #3,276 of 5,703
Big shout out to those that recommended the Pelican 1040. I don’t think there’s a more perfect carry case! I think the clear cover is best. It gives me joy to find things that perfectly fit as if they’re custom.
Mar 15, 2022 at 1:26 AM Post #3,277 of 5,703
https://www.head-fi.org/threads/fii...estionnaire-in-post-2901.954441/post-16846294
Yes, I have the same short sharp loud clicking noise when changing tracks from flac to MQA or to DSD. I noticed that this happens only when starting to play different track format and only at the begining of song for the first second of track playing. I have done full system reset in settings menu several times and now this problem is not noticed so often. Other users also reported about this problem several times but FiiO does not respond about this thing. Yes, it is irritating but I got used to it.
Mar 15, 2022 at 4:23 AM Post #3,278 of 5,703
A large white screen appears when running Apple Music on FiioM17, and no touch operations can be performed
Are you using the Apple music app in latest version? If not, please try to update it first. Which page were you trying to enter?
Best regards
Mar 15, 2022 at 12:27 PM Post #3,279 of 5,703
@Ichos
In DC mode,The battery will be charged if it is not fully charged. But the battery will not provide any power at that time.
Best regards
Safe to leave the M17 on DC power charging overnight, with no negative effect on battery life?
Mar 15, 2022 at 4:02 PM Post #3,284 of 5,703
Question for those who are using the iFi power supply? Do any of the adapter options you have fit the M17 snuggly? All mine are loose.
Mar 15, 2022 at 4:08 PM Post #3,285 of 5,703
Mine is fine, it's tight enough. I use the iPower Elite 12V4A and with the Monolith THX 887 I use the IPower Elite 24V2.5A ..
