I can't seem to be able to install the new Fiio app update on my 11 pro. Get the error message stating 'Can't install this update'. Anybody else ran into this?
FiiO M11Pro | Dual AK4497 | THX AAA 78 Headpone Amp | 5.15" 18:9 720P | Exynos 7872 | 3G Ram+64G Rom |
- Thread starter JamesFiiO
- Tags
- fiio fiio m11 pro
senorx12562
Mine installed itself.I can't seem to be able to install the new Fiio app update on my 11 pro. Get the error message stating 'Can't install this update'. Anybody else ran into this?
Dear friend,I can't seem to be able to install the new Fiio app update on my 11 pro. Get the error message stating 'Can't install this update'. Anybody else ran into this?
You could try to download the app again and try: https://drive.google.com/file/d/14MI0D-6bN4ETP7lk3W-vIZPG_DVW4quE/view
Best regards
Dear friend,Thank you @FiiO ! Nice update. Love the VU meters. Cheers!
P.S. Waiting for M11 + LTD (Stainless Steel) to get to a USA store
Thanks for your interest. You could get one from our seller in Amazon instead: https://www.amazon.com/dp/B0953DRBJG/ref=cm_sw_r_u_apa_glt_fabc_JKSN847RFF9H6K9ZRWJY
Best regards
This worked! Thank you @FiiO for your quick support!Dear friend,
Best regards
edit: loving the VU meter!
There are some features I’m really missing, amongst which is AAC for BT but I understand this is SoC limitation.Dear friend,
Are there any new features you would like us to add for the M11Pro still? The engineers are still working on the new firmware now.
But the biggest thing I am missing, and what is keeping me from upgrading to M11 Plus, is the lack of system-wide EQ. I know this is a feature with a lot of debate, but in my opinion 700$ DAP’s should have a system-wide EQ if even a simple phone can have it. I hope you will consider this in future FW upgrades.
Other than that, I think the M11 line is great and I love my M11 Pro and the fact that you’re engaging with us here on head-fi!
Regards
geokite
- Jan 6, 2009
I would like to see the following feature:
If the screen is flipped on the player (so the plug is on the top), the volume wheel would also be reversed. In other words, no matter what the orientation of the screen, no matter where the plug is (top or bottom), rolling the wheel up increases the volume.
Dear friend,I would like to see the following feature:
Thanks for the kind feedback. We will report to the engineer for assessing about that.
Best regards
Not exactly sure how this happened but a limited number of new M11 pro’s just showed up on Amazon sold by Fiio. I would guess it’s “found” inventory.
Amazon.com link
Amazon.com link
Yes, this is our authorized seller.Not exactly sure how this happened but a limited number of new M11 pro’s just showed up on Amazon sold by Fiio. I would guess it’s “found” inventory.
Amazon.com link
Best regards
Dopaminer
Member of the Trade: Audio Dopamine
- Sep 6, 2013
So I installed the new FW on my M11Pro. I now apparently have two versions of FiiO Music. It/they work, however there is a major problem I cannot get around - the FiiO Music app is preventing any other app from opening. If I close FiiO Music, it instantly restarts. I don't have a chance to see the desktop to start any other app.
When I reboot the player, FiiO Music starts automatically -actually, 2 versions of it start automatically. I cannot get around this. The only other parts of Android I can access are the settings - I have gone into the Apps setting and 'Force Stopped' FiiO music numerous times - no result. The 'Disable' function is grayed out. I have also toggled back and forth between Android mode and Pure Music mode - no difference. I have rebooted numerous times - no difference: FiiO Music starts up, and if I try to shut it down, it instantly restarts. I have no access to the desktop or other apps.
This is a huge problem for me because 50% of my use of this player is wifi-casting to networked speakers with the Hifi Cast app. FiiO Music is preventing me from accessing this and all other apps.
Does anyone know a solution for this? Hoping not to have to factory re-set....
TIA
David
Two versions of FiiO Music:
TIA
David
Viking31
What new version of firmware are you talking about?
Dopaminer
- Sep 6, 2013
Sorry - I should have said the latest update for FiiO Music App: V3.0.5What new version of firmware are you talking about?
I finally got past my dual FiiO Music Zombie Apps by turning off all their permissions in Android app manager.
But unfortunately now the other apps are all misbehaving.
I have a permanent notification covering half my screen wanting me to choose FiiO as the default launcher.
Hifi Cast - I have the premium, paid version - no longer works.
It also seems my M11 Pro's wifi will not stay connected.
This M11 Pro had worked flawlessly for over a year until that last update. Seriously, 30+ years of dealing with software in my life and developers still cannot get even an incredibly simple device like this to be stable.
Dear friend,Sorry - I should have said the latest update for FiiO Music App: V3.0.5
Sorry about that. Did you install the correct M series FiiO Music app instead of the one for mobile phone or X series player?
Please check whether this version works fine for you instead: https://drive.google.com/file/d/1WUqTWvvlfk2mEC7FxjGfP_rBbxa-FA4V/view?usp=sharing
Best regards
rlw6534
What are the version numbers for the two versions? One of them is probably not the correct one. I would recommend going to settings, apps and uninstalling (or uninstalling updates) for both versions until you are left with the original system version. Reboot and then install the latest update for "M" series players. Do not install the version from the Play store - it's not intended for Fiio DAPs.
