FiiO M11Pro | Dual AK4497 | THX AAA 78 Headpone Amp | 5.15" 18:9 720P | Exynos 7872 | 3G Ram+64G Rom |
Jun 20, 2023 at 11:22 PM Post #1,921 of 1,931
Hi everybody,
As the owner of the m11 Pro, I am trying to use it as a streamer in following way :
- music stored on NAS
- mi 11 Pro connected to same network as NAS
- mi 11 Pro with UAPP or Neutron installed and used as media renderers
- mi 11 pro controlled by Emby from computer.
The problem is, after 2/3 tracks it stops playing.
Any idea what the problem can be ?
Dear friend,
Can the FiiO Music app help instead? And does the issue happen in certain music? If you are convenient, you could try another server or Wifi to check again.
Best regards
Aug 3, 2023 at 9:35 AM Post #1,922 of 1,931
Hi @FiiO, do you offer the battery replacement service for M11 pro or sell the battery independently?
Aug 4, 2023 at 2:58 AM Post #1,924 of 1,931
Mar 9, 2024 at 10:31 AM Post #1,925 of 1,931
Hi,
For several reasons, I recently performed a factory reset on mmy Fiio M11 Pro (the Dual AK4497 version).
After the upgrade, I did try to reconnect to the Google Play Store to install the required apps.
I enter my login and passaword and then I am in...
But each time I try to do anything on the Play Store, it quits with a message "The app keeps crashing".
Hope there is no incomptaibility between the Google Play Store and the older Android version that is in this device :frowning2:
Mar 9, 2024 at 10:57 AM Post #1,926 of 1,931
That is the risk of such devices. They are rentals and will become bricks in a matter of years. Hopefully the ability to play local files remains as the device ages out of functionality. Good luck with things.
Mar 9, 2024 at 11:00 AM Post #1,927 of 1,931
Hi,
Thanks for your answer.
I found a workaround for the problem.
The factory reset installs the Fiio App Store. I opened that and from the Fiio App Store installed APKPure app.
Once installed, I updated the PlayStore from within APKPure.
Now works like a charm :)
Yes, those DAP's may get outdated.
But probably n,ot with the Google Play Store which I think is backwards compatible with android 3 or 4...
So we probably still have a couple of years before our DAP is good for trash... or only local playback.
Mar 9, 2024 at 10:49 PM Post #1,928 of 1,931
Hi,
Nice to know. That is great backwards compatibility for sure. Good business sense.
Apr 23, 2024 at 11:36 PM Post #1,930 of 1,931
Hello. I am using Fiio m11 pro. I want to buy Sennheiser Ie 900 as IEM. Do you think it will fit? How will they fit together? Thank you very much for your help.
Dear friend,
Yes. And if you could find a suitable balanced cable, you could try the balanced output of M11Pro for connecting the headphone.
Best regards
