ouch.. glad it looks like that was the only major damaged item... that's scary...
My M11 decided to become one with nature today.
Hey peeps! I have noticed my FiiO M11 shows the "first" song's bit rate... and I need to quit Plexamp (or whatever app that's playing the music) to "reset" the bitrate.When I do a factory reset 3.0.3 is what it returns to so I would say yes.
Good luck... if it's not under any warranty, it'd try with a blow of compressed air as it feels like something might be stuck there...My M11 volume dial has been disfunctioning for some time now. Instead of volume down it turns the volume up while volume up functions fine.
Anyone any idea as to how to fix this without having to send it to Fiio service?
yesGood luck... if it's not under any warranty, it'd try with a blow of compressed air as it feels like something might be stuck there...
Sliding the screen... That's still "normal", right?
Thank you.I had the same volume wheel issue. I contacted Fiio and they first told me to send the M11 to China, something I was a bit reluctant to do. I asked them if their was a way I could fix it myself, they sent me basic instructions (below). There was no dust that I could see, but removing the wheel and putting it back somehow fixed the issue. It's not perfect, but it's much better now. It's not difficult, but you need to be careful and definitely need the tools shown in video. Good luck if you want to give it a try.
Thanks for your cooperation in advanced.
And disassembly video: https://youtu.be/O_W6vLQlZrs
Reason may be damp or dust (the volume wheel).
Have a nice day!
Best Regards,
FiiO Customer Service Lee
Too complicated to bother though for now.
I think I'll just set a maximum volume limit so that I won't destroy my eardrums and stop using it altogether.
Can you repurpose the other buttons so that the perform the volume function?
Thank you.
Thank you.
This actually worked!Maybe you could try first using contact spray.
Did you leave it on the grille too long?
Absolutely! All you need to do is add the artwork to the album folder like this. I don't think it matters what you call it, but I always use "cover". That will apply It to every song (I only use FiiO music, so I'm not sure if this applies to alternative apps)hi guys - is there a way of assigning album art to the whole album, rather than track by track. I can't see an option to do this...
