iamloco724
- Sep 29, 2009
Yes what are you using headphones or any other monitors?
Right now I'm trying out a few I'm between blon 3, ISN H40 and Moondrop Starfields
Any recommendations for a good 4.4 cable replacement?
Have you made sure your M11 is in Storage mode from the pull down menu? Are you not able to go into USB DAC mode either when it is selected?Guys I need help, for some reason I cant access my M11 with my computer at all. It simply shows it is charging, nothing else (not even the sound windows makes when you connect something).
I tried the same cable with my smartphone and it works no problem.
I tried another cable with the M11, same results.
I tried connecting it to my laptop, same results.
I updated the M11 to the latest software and also my computers, same results.
I tried rebooting my pc and the M11, same results.
I simply dont get what is happening, I havent dropped it or anything and it actually worked just fine up until just now (it worked earlier today...)
Yes, storage mode it is.Have you made sure your M11 is in Storage mode from the pull down menu? Are you not able to go into USB DAC mode either when it is selected?
Dear user,Guys I need help, for some reason I cant access my M11 with my computer at all. It simply shows it is charging, nothing else (not even the sound windows makes when you connect something).
I have installed the MTP driver and the folder does not appear at all. That page does not appear either. It has worked for me for an entire year but just suddenly stopped working.Dear user,
What's the operation system of your computer? Have you installed the MTP driver?
Can the FiiO driver folder appear in your computer?
And does this page appear in your M11 after connecting?
You could also check via other usb port.
Best regards
Any help please ?a little problem and i need help....2 days ago i installed the beta formware and i had some bugs so i went back to the official one...since then fiio player does not open at all...whats the solution??
i see now my fiio music app is 1.1.9 and when i try to instal the one from the site 1.1.8 it does no install
Have you tried installing 1.2.0 after uninstalling 1.1.9?Any help please ?
