bujinkan
- Feb 18, 2015
first of all 1.2.0 is for android phones and second i cant get back to 1.1.8Have you tried installing 1.2.0 after uninstalling 1.1.9?
Dear user,so the problem with fiio music app seems to be this.
when i instaled the beta firmware the music app went to 1.1.9
when i istaled again the official firmare the app music stayed at 1.1.9 and i cannot get back to 1.1.8...
please fiio a solution? the fiio music app wont start at all
Dear user,I see on your website at https://fiio.com/newsinfo/412218.html, you've released a new version of The FiiO Music App (v1.2.0) for Android devices. But that update also says Don't update this version if you are using M11/M11PRO/M15.
I thought the M11 was an Android device?
Thanks for clarifying that.Dear user,
If you would like to update the FiiO Music app, you could update the beta firmware instead. If you install the verison for other Android devices, you may lose some features when using the M11.
Best regards
Just want to make sure I understand one more thing...
In order to use the Fiio HiRes Driver in the M11, I have to use UAPP?
I've already paid and have been using UAPP with great results so it's not much of a problem, BUT, there are some apps like for example Plex that do not work with UAPP. So in that case, my only resort is the original android driver in the device which definitely sounds inferior.
Is that what everyone is seeing or am I missing something?
65-75, Low gain, Etymotic Research ER4SR, 3.5mm POJust a general question out of curiosity and I know there's a lot of variables but what volume on average does everyone listen to there M11 at?
I think if you go Settings<Apps<FiiO Music<Storage and clear data and cache you should be able to open the app up.Any help please ?
Dear user,
Best regards
That happened to me, and I solved it by factory resetting the M11. The installation may be corrupted.Unfortunately, the newest beta firmware (from June) causes music to "stutter" during playback on my M11. Happens pretty consistently. I've rolled back to the last official FW (March 26) due to this problem.
FiiO Music app is version 1.1.9.... Wish they would release a new version soon!
Thanks. I'll try installing the beta FW from June and then following with a factory reset.That happened to me, and I solved it by factory resetting the M11. The installation may be corrupted.
