[FiiO M11] Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
Dec 20, 2019 at 12:54 PM Post #7,338 of 9,308
In the FiiO player, do people hear a slight click when a track is selected, especially when changing to different sampling rate tracks ( never heard it with Poweramp) ?
Does their player crash more than it would be expected to ?
Yes - absolutely hear the click when switching between sampling rates! And yes - I find it crashes semi-regularly as well.
Dec 20, 2019 at 11:46 PM Post #7,345 of 9,308
Hi.
Can i use my M11 as a DAC for my iphone if i connect it via USB-Lightning?
Thx.
J.
You'd need to use the Camera Connection Kit or similar if it is to work. If that is how you are going to use it, why not just get a Q5S instead?
Does anyone know where I can purchase a longer TRRS (4 pole) digital coaxial cable? I have the FIIO one but I need to have a longer one ...
Someone would have to make it by hand, as it is unique. I know that Moon Audio makes them. I bought a length of the wire directly from Moon Audio (when they were selling it for DIY, not sure if they still do) and made my own.
