[FiiO M11] Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
Sep 26, 2019 at 11:05 PM Post #6,706 of 9,308
Thanks, didn't like the Meze 99 at all.
I listen to hip hop, soul and rnb.
Which is why i went for the v modas.
I've tried many before and nothing felt as good as the v moda.
But I'm looking for q change.
I also want a tight feel with the over ears.
Hope that makes sense
Hmm, thTs interesting. I listen to the same, which is why I switched to the Meze. The bass is deeper and more potent, blending well with those genres. I hated the new earpads and switched to the originals as soon as I got mine.
Sep 27, 2019 at 3:13 AM Post #6,708 of 9,308
Dear friend,
Did you try other wifi and check again? Make sure that the M11 and the mobile phone are in same Wifi.
Does the same issue happen when connecting to other Bluetooth headphone? If not, try to forget the 100XM3 in the M11 and reconnect again?
Best regards
Thank you for the response I will try these options...congratulations on this excellent customer care, brilliant...
Sep 27, 2019 at 4:16 AM Post #6,711 of 9,308
To bad that the M11 Pro also lacks Google Play store support, same as the M11. Hopefully the next high end Fiio player will again support it.
Until then my X7II will do.
As far as I know the M15/M15 Pro will share the same SoC as the M11/Pro, so no Google Play. If that’s what makes the biggest difference for you, look elsewhere. The M11/Pro have already far surpassed the X7ii interface, speed, usability and screen quality, and the M11 Pro will more than likely surpass its SQ too.
Sep 27, 2019 at 4:24 AM Post #6,712 of 9,308
For those looking for a cool carry case for the M11/Pro, especially for traveling with IEMs and other accessories, I found this on Amazon (received today):
https://www.amazon.com/gp/aw/d/B07JBB2TCS/ref=ya_aw_od_pi?ie=UTF8&psc=1
Ignore the fact that it’s marketed for a Wahl shaver. I did all my measurements in advance. Can you get more perfect?
0F5CB4A3-C3B2-4437-BD1B-713356D93497.jpeg 72FBE0B0-A0E8-42BD-98ED-E7E24467445C.jpeg A2D946FF-79B9-4367-A301-A3AF3ACE3EC1.jpeg 4E75F245-B21B-4195-87C9-FE7F0282D018.jpeg
Don’t go and spend $40 on a “hifi” case from DD that’s a tight fit (you can’t get a protective IEM case inside the DD, for example), when you can get this beautifully made, hard shell, soft lined case with a carry handle for the sun total of ~$10!
Sep 27, 2019 at 6:19 AM Post #6,714 of 9,308
To display all album covers, the cover must have the name Cover or Front.
I have over 700 albums and about 70% of them display on the M11 but none of the ones that do display have cover or front in their titles...??
Sep 27, 2019 at 6:26 AM Post #6,715 of 9,308
I use musicbee to sync music to my M11 and to get album art to show I have to set it to embeded in the music file
Sorry on another planet thanks to illness and new meds :)
Sep 27, 2019 at 6:35 AM Post #6,716 of 9,308
I have over 700 albums and about 70% of them display on the M11 but none of the ones that do not display have cover or front in their titles...??
I always run my albums through mediaMonkey to get album art and tag it.
With it you change artwork properties to 'Front' for each albums track.
Abit of a chore to go through all your albums and fix, but it sure looks good when it works.
It also has an API where it connects to Discogs and downloads the artwork into the albums folder.
Sep 27, 2019 at 6:37 AM Post #6,717 of 9,308
Edited to add
You install the software on a PC. Unfortunately on Android it needs Google play services to run on the M11.
Sep 27, 2019 at 7:33 AM Post #6,718 of 9,308
I can only recommend manually finding albums and correcting titles in the attached pictures. Or, before downloading a new album to a memory card, add a cover using the "Metatogger" application (though it does not work with DSD / wav formats)
