[FiiO M11] Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
gmahler2u
- Dec 19, 2011
Hope you enjoy it as much as I am
Juj
Thank you sir
gmahler2u
- Dec 19, 2011
Where do you guy get your balance cable?
I tried aliexpress once but cheap but pretty bad quality. Anyone experiencing bad cable from aliexpress?
DrKrFfXx
- Jan 15, 2013
What headphones are you going to use?
Jujoe
It depends for mmcx I use https://www.amazon.co.uk/gp/product/B07F9LP6YN/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1 This ok for a cheapo
For my Audeze I use https://www.amazon.co.uk/gp/product/B07MNNFQB6/ref=ppx_yo_dt_b_asin_title_o09_s00?ie=UTF8&psc=1 This sucks but works
Hope this helps
Juj
gmahler2u
- Dec 19, 2011
I used the the comet. I still have jh16 2pin and Roxanne too...
gmahler2u
- Dec 19, 2011
Hope this helps
Juj
Looks similar to mine..how is that cable? Mine cause on and off left side...i should try..
gmahler2u
- Dec 19, 2011
Meijuner only in uk Amazon..not in us Amazon.
gmahler2u
- Dec 19, 2011
Whose using 4.4 plug and 2.5 plug.
Which one is better?
Thanks
Thanks
jmills8
Previously known as bmiamihk, jmills2
Been asked a few times. Either one your choice.Whose using 4.4 plug and 2.5 plug.
Thanks
Ryokan
Been through settings can't find how to format card in situ. Or can it only be formatted on comp?
fatmanny
I'm in the same boat. I absolutely love this player and it's a great choice for a first.My first fiio dap, i can't wait for m11.
I finally pull the trigger.....
Jujoe
How do you feel about m11 low end is it good controlled, reaching good lows, don't feel that it's lacking there.? As from fiio i know they intentionally reduced low end ammout and don't know how it came to the final sound as i haven't heard m11. Still afraid that fiio castrated bass as they make it more "audiophile" type that means more middle and treble pronounced. This dac and amp is capable of powerful lows and why is it done by fiio i don't know. As i think many there loves lows and good bass.I'm in the same boat. I absolutely love this player and it's a great choice for a first.
fatmanny
It's definitely not as bass heavy as it could be, but it certainly delivers when it's there. I've read in the past on this thread that it is neutral but accurate, so if there is bass in the track there will be bass being pushed through. But remember that whatever headphones you use will have a large impact as well. I'm using the Tin Audio T2, which don't have much for bass, but the combination of the two please me enough with bass. I don't have much to compare this player to but, to me, it's smooth sounding.How do you feel about m11 low end is it good controlled, reaching good lows, don't feel that it's lacking there.? As from fiio i know they intentionally reduced low end ammout and don't know how it came to the final sound as i haven't heard m11. Still afraid that fiio castrated bass as they make it more "audiophile" type that means more middle and treble pronounced. This dac and amp is capable of powerful lows and why is it done by fiio i don't know. As i think many there loves lows and good bass.
Total: 6 (members: 0, guests: 6)
