[FiiO M11] Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
shadow84
- Feb 7, 2010
What would be the best way / settings to maximise battery life? I intend to turn off wifi, bt or if its has airplane mode.
Caguioa
- Aug 18, 2014
I will be upgrading from an ipod classic, how big of a leap would this be.
my headphones I will be using are is shure 846, Will I need anything special like an amp for m11?
and do u need an amp for full size headphones to run m11? I plan on getting hd800S for my m11, unless there are better DAP out there.
pinche juan
Like 4-5 days. I don't know if they open all the boxes but they opened mine to add the sd card.How long did it take to deliver from order placed? Also is that the company that opens all the boxes before shipping?
abitdeef
Formerly known as ihatepopupads
- Oct 30, 2003
Huge upgrade from an ipod classic.
Hi.
I have questions about ldac
I tried connecting my BT headphones (Sony WH-1000XM3) on Note9 & Fiio M11.
Both support LDAC, but I find that it has different results.
I'm not sure if I understand anything wrong.
Fiio M11 does not support LDAC or Poweramp does not support BT Fiio M11?
Fiio M11
Samsung Note 9
- Poweramp version V3 Build 830
- Fiio M11
- Android 7 Fiio V1.0.5
Fiio M11
Samsung Note 9
G_T_J
Now available in stock at AMP3 players
abitdeef
- Oct 30, 2003
Hi.
- Fiio M11
Fiio M11
Samsung Note 9
Do you have to go into the developers menu and change something? Or in the menus somewhere? I forget how to get to the developer's menu.
But it has to support full ldac, oh fiio?
Fiio M11 run on Android 7.
No menu BT setup in developer menu
abitdeef
- Oct 30, 2003
Oh yeah that's right, hmm. I'm sure fiio will sort it out. Only ldac in pie. It's weird you're getting the ldac icon but bitrate isn't right. Haven't messed with Bluetooth yet myself.
lesale08
Just saw this on youtube.
jmills8
Previously known as bmiamihk, jmills2
Claws
zeroselect
I am also waiting on my M11 and the issue seems to be on certain SD cards. Fiio has address this problem in a post. I will be running 2-512gb Samsung microSD but looks to me i won't be having a problem.My M11 arrives tomorrow.Is it still advisable to use the second SD card slot if you are going to only use one card or has the issues with slot one that were reported here been fixed through firmware updates? Im going to be using one 64GB SanDisk card. Thanks
https://www.head-fi.org/threads/fii...involving-micro-sd-slot-1-on-fiio-m11.904457/
fatmanny
Fiio's Facebook page are giving away some FH7 as a draw. Go check it out!
abitdeef
- Oct 30, 2003
I don't have Facebook
Total: 8 (members: 0, guests: 8)
