Thanks for the answer. I quite like the standard FH7 cable and just wondered it you could purchase a 4.4mm version. What pure copper cable did you have in mind?
[FiiO FH7] Flagship 5-Driver (1DD + 4BAs) Hybrid In-Ear Monitors, Knowles DFK + SWFK Composite BA Drivers, 13.6mm Beryllium DD Driver
https://www.headphonesty.com/2019/11/review-fiio-fh7/Thanks for the answer. I quite like the standard FH7 cable and just wondered it you could purchase a 4.4mm version. What pure copper cable did you have in mind?
Stock cable is lc-3.5c according to this review
Hanesu
Stock cable is this one:Thanks for the answer. I quite like the standard FH7 cable and just wondered it you could purchase a 4.4mm version. What pure copper cable did you have in mind?
https://www.fiio.com/productinfo/39900.html
And can be purchased in the Fiio Online Shop!
By the way, are you still selling your lc - 4,4d cable? You "bumped" it several times in the "for sale" section and I wrote you about it, but never got a reply? So I guess you sold it already?
Thanks!
Sorry it is. I'll update the auction to reflect that.
Hanesu
Ok, thanks!Sorry it is. I'll update the auction to reflect that.
Questionnaire About Earphone Types(Note: that this questionnaire is not limited to earphones of FiiO brand)
Distinguished users,
To better know your preference and design suitable earphones for you, we made this questionnaire about earphone types and would like to sincerely invite you to participate in it. Thank you so much for your support and advice.
>>>Click here
>>>Click here
MarkParity
>>>Click here
about:blank#blocked Link not working for me.
Please try this link instead: https://www.head-fi.org/threads/que...earphones-of-fiio-brand.957018/#post-16274567about:blank#blocked Link not working for me.
@FiiO - I purchased the FH7 last spring, and paired them with your BTR5. They sounded amazing, I did notice some time I would get a popping or cracking sound, I switched filter back to the reference as I was using the bass filter. Now they seem to be completely blown and popping and cracking sound at every volume all the time. The are definitely blown, does Fiio back this product or is there a manufacture warranty or any assistance that can be provided???
Dear friend,@FiiO - I purchased the FH7 last spring, and paired them with your BTR5. They sounded amazing, I did notice some time I would get a popping or cracking sound, I switched filter back to the reference as I was using the bass filter. Now they seem to be completely blown and popping and cracking sound at every volume all the time. The are definitely blown, does Fiio back this product or is there a manufacture warranty or any assistance that can be provided???
Does the same issue happen when using the BTR5 with the other headphone? Or use the FH7 in other device? You could contact support@fiio.com about that with your receipt attached.
Best regards
No it does not happen to my other headphones.Dear friend,
Best regards
shinbojan
- Jan 7, 2015
Is there anything better in 500e range?
A friend of mine will be visiting in two weeks (he lives in Germany), so wondering if I should order this or something else.
I would advise you to give a read, here on Head Fi, on the comparison between the Fh7 and the Blessing 2Is there anything better in 500e range?
Then if you want to go a little higher there are the Clairvoyance ...
CK Moustache
I'd recommend checking out the DUNU DK 3001 Pro (I've compared the FH7 a little to them in the tonality section of my review https://www.head-fi.org/threads/956208/#post-16219138) and Sony XBA-N3 (discontinued but still available, for example on Alza).
What I personally really don't like about the FH7 is how dominant and exhaustive, intimate their central midrange at 1 kHz is. Otherwise the tuning is quite decent.
shinbojan
- Jan 7, 2015
I have 2000j now, so I would rather skip Dunu (I also don't like the looks of 30001 pro).
They would probably be way pricier in Europe.
Total: 10 (members: 0, guests: 10)
