You're kidding, right. I didn't know glue was electrically conductive. I'm RMA ing it back. Once would have been bad enough, but twice is shocking. I had many IEM's of the years and never had this issue.
[FiiO FH7] Flagship 5-Driver (1DD + 4BAs) Hybrid In-Ear Monitors, Knowles DFK + SWFK Composite BA Drivers, 13.6mm Beryllium DD Driver
aleniola76
thanks, it works almost fine, it is just less firm than the L IEM, which means sometime it will disconnect if I am touching it. I will see how this goes in the next days and eventually get in touch with my trusted seller.Dear friend,
If the output works fine, having click or not does not matter a lot. But if this click affect your daily usage, you could contact the seller or support@fiio.com for help.
Best regards
That said, it is an amazing set of IEM, I am impressed by the sq
Gerardo Trezza
- Feb 18, 2017
Hello
i need a suggestion
i am starting to buy FH7 to share with m11plus any comment?
Also i see FH7 doen't have 2.5 cable ( i have f9 pro and there it was present)
any suggestion about the 2.5 cable i have to buy?
thank you so much in advance
i need a suggestion
FiiO FH7 review: Outstanding IEMs for live performance use and more --From techaeris Alex Hernandez
https://techaeris.com/2021/08/10/fiio-fh7-review-outstanding-iems-for-live-performance-use-and-more/
Wrap Up The FiiO FH7 IEMs are outstanding. It’s hard to call something the best of the best because there’s always another product around the corner I have yet to review. But right now, at this moment, these are the best IEMs I’ve personally used to date for live performance. Until the next pair.
Aliexpress store link: https://www.aliexpress.com/item/33019143358.html
Gerardo Trezza
- Feb 18, 2017
Thank you so much FiioFiiO FH7 review: Outstanding IEMs for live performance use and more --From techaeris Alex Hernandez
i already know where to buy FH7, in my post i mean what 2.5 balanced cable i have to buy and where thank you so much in advance for the reply
Hi. If you discount the FiiO's Silver "D" spec cable, is there any consensus as to what is a good replacement cable for the FH7? I've had two faulty "C" spec cables that came with the FH7 so won't be buying FiiO again, as I have lost all faith in "C" spec FiiO cables. It's not the headshells, as the cable from my FA7 works perfectly.
Dear friend,Thank you so much Fiio
The cable comes with the FH7 is the LC-3.5C cable. Can it meet your need? If yes, I think you could consider our LC-2.5C cable for help, just for reference.
And if there are local store in your city, you could have a try there first.
Best regards
Can't find the "C" cable anywhere to replace my second faulty one!!!!
Shopping Celebration of AliExpress in August - FiiO Official Store
FH7: original price 399.99 USD, promotion price 299.99 USD (25%off)
Access to the FH7:
https://www.aliexpress.com/item/33019143358.html?spm=5261.ProductManageOnline.0.0.47484edfVgUXhe
Start and End Time (PDT):
2021-08-23 00:00:00 - 2021-08-27 23:59:59FH7: original price 399.99 USD, promotion price 299.99 USD (25%off)
Access to the FH7:
aleniola76
good morning @FiiO , I purchased the UTWS3 BT adapters for my FH7, but I am having some issues connecting to a Windows 10 laptop.
I can pair the UTWS3 with the laptop, but then the device is recognized as a generic one and not audio.
Any suggestion ?
Thanks
Any suggestion ?
Thanks
Dear friend,good morning @FiiO , I purchased the UTWS3 BT adapters for my FH7, but I am having some issues connecting to a Windows 10 laptop.
Any suggestion ?
Thanks
Please check whether the UTWS3 is recognized as Bluetooth hand-free audio instead of stereo? And you could try to clear the pairing of the UTWS3 and reconnect again for check?
Best regards
aleniola76
The UTWS3 is recognized as "Other Device" and there is no option to set it as a sound device.. I can pair it, but I cannot connect itDear friend,
Best regards
Dear friend,The UTWS3 is recognized as "Other Device" and there is no option to set it as a sound device.. I can pair it, but I cannot connect it
You may go to 'my Bluetooth device option' in 'computer'. Does the UTWS3 show up there? If yes, please try to right click the A2DP option and connect it.
Or try to clear the pairing for the UTWS3 to search it again?
Best regards
aleniola76
Thanks for your replyDear friend,
Best regards
I tried to unpair and pair again, but no changes.
I still see the UTWS3 as "other" and the only option I get is "Remove Device" :
I tried checking the drivers and this is what I get :
Is there a specific Driver I should look for ?
Anyone? If not, I am literally throwing them in the bin. No good to as they are.Hi. If you discount the FiiO's Silver "D" spec cable, is there any consensus as to what is a good replacement cable for the FH7? I've had two faulty "C" spec cables that came with the FH7 so won't be buying FiiO again, as I have lost all faith in "C" spec FiiO cables. It's not the headshells, as the cable from my FA7 works perfectly.
