Kevinchen
- Nov 17, 2010
Please try to plug and pull the "LINE IN" socket in the rear panel several times.
hi. the 3.5mm line in is always unplugged when the e7 is docked. same problem. apart from this issue, very clean sound from the combo, first time venture into amps but experience marred by right channel silent when docked
Quote:Our engineer just tole me that it may also cause by the 3.5mm line out jack! please plug/unplug the 3.5mm line out socket again!
There are a switcher inside the socket to bypass the headphone output when using adjustable line out!
hi could you tell me why my right channel becomes silent when i dock the e7 /e9? i sent an email today to pjbox.co.uk,
[size=inherit][/size]
Hi, i spoke to you earlier today about an issue with the fiio e7 and e9 bundle i recieved yesterday when they are docked and only when they are docked. initially, the right channel unpredictably became silent when they are docked. this is frustrating when i am listening to something and having to reseat. currently each time i reseat i am not getting any sound from the right channel. i have tried different headphones and it is not the headphones that are causing this issue. when i connect everything without docking it works ok but the clarity of the sound when docked is much better imo. i asked about the RMA procedure and i was told that new stock will be coming in on the 20th decemeber. i would like a replacement to both units. as i dont have another e7 or e9 i cannot test which unit is faulty when docked (problems only occurs when docked). i purchased the bundle so that they could solely be used whilst docked and at the moment i am not happy with my purchase due to this fault.
what can be done about this?
hopefully something can be done about it
Sorry for the problem!
Please will you help me plug the E7 into the dock, and make sure it is reliable connect!
when i connect as number 4 in the image, the right channel is silent
when i connect as computer>e7>e9>headphones (through line in) everything is ok, sound quality not as good as when docked
Guess the troubleshoot didn't work. Either way just wait patiently until you are able to make the exchange. I think we've already established that you have a faulty unit; no need to spam all the E9 threads over it.
I have a pair of DT990/250s and the E7. Will this make a noticeable enough difference to justify buying it or would I be better off getting a pair of higher ohm headphones first?
