R-Audiohead
- Dec 4, 2010
I just got a text from UPS that my E7/E9 was left on the front porch . My girlfriend does not get home until 6 so let's hope it doesn't rain.
Also I have another question that I posted in the E7 thread since it is related more to the DAC but maybe you guys can answer here. I bought the special edition Beatles Remasters that comes in a USB drive with 24bit FLAC files and 320k mp3. Since the E7 can only do 16bit am I going to get no sound when trying to play the 24bit FLAC files? I have been using my stereo receiver which does 24/192 optical from my PC so I did not think about it until now.
They'll play, but you won't be utilizing the hit bit rate of the FLAC files. The FLAC and 320kps will most likely sound comparable. As much as it makes me cringe to suggest daisy chaining (my background comes from larger scale electronics), if you do have a PC sound card which does 24bit (a surprising number of computers in the last couple years have them) I bet running a 3.5mm male-male to the 3.5 input on the e9 from your headphone out will produce better results with the FLAC, but probably not as much with the 320kps. You won't need the e7 docked for this if you wish because you won't be running DAC. I plan on tinkering with this with when I finally pull the trigger on an e9 later this month. Maybe I'll post something short for the community.
I also recommend playing with the volume outputs on each "amp" if you do this to find the optimal listening experience. My guess is you want the e9 doing most of the work, depending on your setup.
