FiiO E17 "ALPEN" - First Impression + Final Thought
Sep 5, 2013 at 9:51 AM Post #6,137 of 6,777
It wouldn't, but if the drivers are giving you troubles and the sound I is actually worse than 48... Take it as a temporal solution till you get time to figure out the actual problem. Better clean sound than clipping or something worse.
Sep 5, 2013 at 11:47 AM Post #6,138 of 6,777
The real question sometimes is "how many 96k album do you actually have", and some are often just up sampled anyway.
As I recall there might have even discussions in the past saying that E17's USB DAC only supports up till 48k and its the coax/optical that goes till 96k?
Sep 5, 2013 at 11:51 AM Post #6,139 of 6,777
USB 24/96
Optical 24/192
Are what the E17 supports and I have used both. My E17 and computer stay at 24/96 all the time in music and games without an issue.
Sep 5, 2013 at 5:11 PM Post #6,142 of 6,777
I remember getting it in Mac. Maybe I remember wrong :D. What it's for sure correct is that I got a lot of grainy sounds with the highest options, and never got it to work properly. Maybe it was actually 24/96. Not a problem with the rest of them.
Sep 6, 2013 at 10:32 PM Post #6,147 of 6,777
You should contact FiiO; something obviously isn't working at this point.
Though it would still be best if you're able to try it on another computer. It doesn't matter if you won't be using it on any other computer; what matters is to know which piece of equipment or software is at fault. No point in getting a replacement unit if only to find out that your computer drivers are the ones that are messed up, etc.
Sep 8, 2013 at 12:05 AM Post #6,149 of 6,777
  I contacted FiiO more than a week ago and I've been getting very slow responses.
I'm starting to hear quiet static when nothing is playing at random times now.
Make sure no other cables are near the E17, your computer, or any part of your setup
I had the same thing with the E17. One of the cables leading to the E17 was on top of and near my light cable and static creeped in
