Hey guys, I've been using the E17 for a couple weeks now, and I've been experiencing a couple issues that I can't seem to get rid of. For background purposes, I'm using these with ATH-M50s, so I keep the volume pretty low since these do not require an amp.
1. If I leave my computer and the E17 on for a few days, it will display a line across the middle of the screen and it will not work properly. I have to reset the E17 when this happens, it's not a huge deal, but the next one is.
2. The longer I have the E17 on, the more distorted it gets. At work throughout the day, the E17 will start out fine, then I start to hear some minor distortion, then it's really noticeable and I have to turn it off and back on. I've tried unplugging the E17 and plugging it back in, only turning it off and on gets rid of the distortion. I've also plugged my headphones directly into the computer, heard no distortion, plugged headphones back into E17, and there's distortion. The distortion is in the mid-high range if that helps. Oh, and I'm also using the included USB cable.
Do I have a defective unit? Any ideas on how to fix these problems?
I Think there is a chance your PC has a driver issue. Did this start right after you got the Fiio or after a few days/weeks of usage?
My Fiio has for example a diffrent issue (now i have to plug in before i turn on PC or some programs wont have sound runing), but i know its related to some driver since i had nothing like that when i first pluged the Fiio in.
For example, when i just bought it, if i was watching a stream, if I changed from the laptop sound to the Fiio, i only had to refresh the stream for sound to load properly. Now i have to restart the PC >D.
Also, before i could have 2 volums working at the same time (Fiio and laptop speakers both had a volume bar in windows), now i only get one.
These things i belive have been disscuesd, and it seems removing the fiio driver from windows and pluging it again solves the problem.
The secondary part would be to know if its not your soundcard that creates this problem. If problem persists, and you still have issues with the sound after some time, i would suggest to:
First, disable sound card drivers (might be enought).
Second, uninstall soundcard drivers, install clean soundcard drivers, then install fiio drivers ( by just plugin in the Fiio).
If none of those work, id try with no scoud card drivers to rule out a driver conflict, and finally, see if there is a incompatibility with the GPU audio driver (if applicable).
Its a lot of work but it might be enought to fix your problem.
