Think you might be getting a little confused - so I'll see if I can simplify it a bit. From your previous posts + what I've read about the D3 & E17 ......
- D3 - you have two options for audio output :
* headphone (analogue) out - using the D3 dac and amp
* spdif (digital) out - using D3 as transport interface only - so bypassing both amp and dac.
- E17 - you have four options for audio output:- depending on input option chosen
* headphone out using E17 as amp only, if fed analogue signal from line-in (most common if used as portable)
* headphone out using E17 as both amp and dac, if fed digital signal (either via spdif or usb)
* analogue line level out via L7 cable - so you're using the E17 as a dac, and outputting a line-level signal - eg to a better amp.
* analogue line level out to E9 (by connecting via dock to L9 amp) - using E17's dac and E9's amp
Now as to your question regarding the iPod etc - unless you have a proprietory cable which is taking a digital signal from the iPod (think HP-P1 or CLAS set-up), then using a standard LOD from the iPod you're only extracting a line-level
analogue signal from the iPod and using the E17 amp only (using the iPod dac). Conversely, if you were using the iPod headphone out, you're using both the iPod dac and amp, then feeding that to the E17 (double amping). Either way, the L7 has no real use, as you're not actually using the E17 dac.
I noticed above that you also seem to be a little confused wrt using the D3 and E17. You mentioned:
D3 ---> optical/coax digital/spdif/cable/adapter ---> Spdif In (E17) ---> L7 LOD --> headphones....
There's no real point in that set-up for two reasons:
[a] You'd be using the D3 as a digital source only - which kind of defeats having the D3. it would be different if it had huge capacity. Suppose it's a different story if you don't like the DAC on the D3 and prefer the one on the E17 though.
Going D3 -> digital signal -> E17 -> line level analogue signal via L7 -> headphones ...... means you'd be left with a line-level signal, you really want an amplifier in the chain somewhere. The whole point of the L7 is to bypass the E17 amp, using it's dac only, and then go to a better amp.
An example of using an E17 + L7 set-up would be:
PC or laptop via either USB or SPDIF to E17 to L7 to tube amp. So you take a digital signal from your source (PC), use the DAC on the E17 to decode to analogue, and then send that signal at line level to your preferred amp.
Hope that helps.
