A Kennedy4
- Nov 24, 2011
Question about the E17. What are the advantages to buying a line out cable like the L1 for use with an iPhone, compared to using the Aux port to connect the iPhone and AMP
UPDATE: This afternoon at work I let it charge for several hours (even though it was probably 75% charged already) and when I got home I tested the aux input for the first time and it worked. Then I hooked it up to a desktop I didn't try it with last night and it worked immediately. Then I tried it with the laptop that I couldn't get it to work with last night and it worked. I don't know what happened but I am not going to complain. This is my first headphone DAC/AMP so I don't have anything to compare it with but to my ears it sounds nice.
How much audible difference does it make? This would be my first Amp too
@bowei006 , Thanks for the informative reply! Will definately get either the L3 or L9. Thanks for the help
Just got mine today...tested it with e9 and K702's and it sounded pretty damn good. Connected to my cowon s9 with MTPC and it also sounded better than my PA2V2.
Great to know it is better than the PA2V2 which many compare to the E11 how much better? noticeably better? How's the bass impact/responce different forom the this than the PA2V2
Regarding that, the PA2V2 only has one setting and that's "ON" where as the E17 has so many different options and 3 different gains...i guess it all boils down to your personal choice of options. Without a doubt i definitely would choose the e17 although it's 2-3 times more costly than the PA2V2.
I don't think the PA2V2 supports SPDIF, looks as sexy, has USB, a wolfson WM8740, 2 amplifiers and an OLED screen.
thanks for your short impression
Having own both, I can say that PA2V2 isn't much of a competition for E17, even on SQ alone.
How is it final review coming along ClieOS?
