Parall3l
lƐllɐɹɐԀ
- May 21, 2011
Just pre-ordered the E17 instead of buying the E10. Head-Fi is indeed a bad place for my wallet.
How much are you paying? If purchased at mp4nation, did you go for fedex or free IEM's?
The headfonia review combined with the OP's post has me sold.
The question is, order it off mp4nation and get $5 off + a pair of brainwavz or wait for it on amazon and pay ~$20 more but get it MUCH faster + better return policy?
If something goes wrong with it and I have to mail it back to HK, it's not going to be cheap.
Mp4nation, 141 USD with the L9 and IEMs, no express shipping. I wonder where the E17s will be sent from. China ? That should be good for me because I'm in Australia.
Does anyone know if it works similar like the E7, where if you plug it to a Mac via USB, you cannot control volume thru the system OS, but rather through the buttons on the device only?
If so, then I will stick with the E10.
dL
That's how the E17 works, but so does the E10. What am I missing?
Maybe I should rephrase.
The reason why I asked is because when I tried the E7 before with the Mac, the volume control on the Mac will change but does not make a difference to the actual volume unless you directly press those buttons on the E7 to change. So I was wondering if the E17 is going to be the same as the E7 in this matter? Because if it is then I will pass. However, if it can act like the E10 where I can change the volume on the Mac myself and it will affect the volume output of the E10, providing me flexibility to change volumes at both the computer and the DAC/AMP, then I'm sold.
dL
Sounds like you aren't connecting your Mac directly to the DAC via USB on the E7 the same way as the E10. Because if you were, then you wouldn't be able to control the volume from the Mac's volume controls of the E7 or E10 being that they are both DACs. Are you perhaps using one of the other inputs on the E10 in order to do this?
I tried this yesterday at Headphone Bar. All I did was directly plugged the USB from the E10 to the Macbook Pro and select the sound output as the FIIO E10 and I can still control the volume on the keyboard as well as control the volume with the dial. I tested it with the headphone port out in the front. I do hear that the dial does not control the volume of the 3.5mm jack output at the back.
I did the same thing to the E7 and while I could control the volume on the Mac, it made no change to the actual E7's output.
dL
Took the fedex shipping! Don't know what to do with those other headphones...
