Hello,
@Koren
If you run the amplifier for 1 hour a day, I would say that it is the tubes that are most likely to suffer and not the components in the Euforia itself.
Because you heat up the tube briefly to temperature and then let it cool down again.
This is definitely not recommended especially if you have tubes that were ultra rare and also expensive.
Here I would say from 2 hours it makes sense to switch on the Euforia, below that not.
It is then better to go to SS amplifier at one hour.
But I have also done it before, when it only ran for 1 hour. you can do it sometimes, but not too often.
Your questions about other tubes.
There were countless manufacturers back then when it was still a mass product.
They were also very reliable in their function but were no longer produced after the war and when transistor technology came along.
That's why tubes are no longer in the focus they once were.
Many manufacturers no longer exist and if you can still find something, it is a remnant, sometimes at exorbitant prices.
Like the Tung Sol 5998 for example, it is a great tube and one of the best for the Euforia.
It's worth the wait for a good price.
That's why it's a bit difficult to say what to ask for.
It also depends on the market, what dealers and Ebay are offering, sometimes you google for a tube and find something about it on Headfi, sometimes not.
The in-house Feliks tube tuning as you know it with the Svetlana and Ps Vane is tuned for absolute neutrality.
The 6AS7G unfortunately masks the detail range, you will notice this when you have bought and tried a 6080 or 5998.
The 6SN7 is much more available and also has a very good influence on the euforia and also brings much more to swap against the Ps Vane.
They have much better textures,bite in the bass,depending on the midrange and treble.
As for the adapter story, the Euforia is mostly fine with it and unfolds even better.
6v6 are great tubes than 6sn7 and again a bit better.
Also, the Dac is what you are looking for and the headphones you are using to fine tune to the tubes.
The Gustard R26 is a great match for the Euforia and brings a lot to the table, best I have heard so far.
If you are rolling tubes, start small.
6Sn7 Foton with a couple of 6080 General Electric will give you a good feel for what you can do with the Euforia.
The rest you will realise what you are looking for and then you can be helped further.
6n5p pipe is unfortunately a dying pipe that will soon no longer exist.
Just like the 6AS7G from Svetlana or Rca or 6080.
6080 is even more common than 6AS7G.
