Deleeh
hello,
@mordy could probably answer the question best.
He has been in the tube business for a long time and can often give valuable tips.
For your second question.
I didn't like the stock tubes.
I have to say that when I got the Euforia I had the Lcd 2C and it was not ideal.
After 2 months I changed the stocktubes to 6SN7 Linlai Elite and 6080 Mullard, then the Lcd 2C had a better grip.
It was less flat and had a better bass range.
The stocktubes masked a lot among other things.
With the Denon D2000 and Fostex th xoo it was a little better.
I then sold the Psvane and made someone else happy with it.
I kept the Svetlana in case I needed to record something, so I could save the good tubes.
I'll tell you frankly, you don't know the strengths of the Euforia yet, no matter if it's the OG, Anniversery or Evo. Even the Elise is actually a beast if you equip it properly and with good tubes.
Cables make a bit of a difference,power and rca cables mainly,the dac I didn't want to believe it myself makes a lot of difference.
And then it depends on which headphones you use, not all pairings with the Euforia are good or satisfactory.
What works very well are Hd800,Zmf no matter which,some planar headphones,Utopia,various Beyerdynamic.
Mainly headphones from 300 ohm you experience the Euforia quite differently.
