UntilThen
- Jun 16, 2015
I use the EF86 in the 339 all the time. I just have not got around to buying adapters to actually try the EF80 so cannot make any decisive conclusions. Some others before me said they preferred the EF86 to the EF80 but I remain curious.
I used to own the Gumby and now own the Yggy. The Gumby is nearly indistinguishable from the Yggy, with a touch more euphonic warmth than the Yggy. The Yggy also slams harder in the bass. I think the Gumby resolves just as much microdetail and conveys microdynamics pretty close to the Yggy, even if the Yggy is more reference level accurate in timbre.
As far as decrapifiers, I have some experience here as well. First, don't worry about at first. Work on the source later. If possible at some point, try to avoid USB altogether, or at the very least try to eventually get an affordable and quality DDC such as the Singxer devices (SU-1) that allow you to feed a USB signal into the Gumby's superior BNC input. This in itself is a great option. But what would be better is picking up a Lynx pci or pci-express card (which can be put in a Thunderbolt enclosure) in order to evade USB from the source to the DAC.
However, there is very solid evidence Schiit themselves (see Mike Moffat's blog) will soon release a highly price-competitive DDC-type device that also allows one to evade USB output from source. Mike Moffat, the designer for Schiit's DACs, hates USB with a passion and repeatedly claims it is the worst input on his DACs, even if his DACs still sound great through them and are a great place to begin.
I would hold on to your NAD M51 instead of picking up the Denafrips. The Gumby may indeed be a more substantial upgrade. I am admittedly quite interested in the Danish Soekris DACs as well.
Responding to the comment about balanced outputs, the Gumby still sounds fantastic through the RCA outputs (that's what I predominately used) and is still better than the Bimby through them. I once owned a Jensen PC-2XR XLR/RCA transformer, which is what Eddie Current uses in their amps to allow for XLR output from the DAC, and I noticed a very marginal difference with the Gumby and Yggy to the point where I sold it. I am currently using the RCA outputs from the Yggy into the 339 and ZDS and feel absolutely zero qualms about it.
Sorry for the OT discussion, but I thought chiming in with the above might be helpful given the recent topic on DACs.
I am glad you are enjoying the EUFORIA; I wish I can hear it soon!
LJ, thanks for responding. I was hoping you would and give your take on Gumby and Yggy. Good to hear from someone who has actual lengthy experience with them.
I don't have the NAD M51. It's the NAD d1050 that I have, hence I'm looking for an upgrade. I think you have just convince me to go for Gumby. Don't think I need the Yggy.
Based on your info on Mike Moffat's impending DDC, I might just hold off on those gadgets and use plain vanilla USB straight from the iMac or PC. I was toying about buying the Schiit Wyred or even the Singxer SU-1 but I will now wait and see what new DDC Schiit will produce.
