warriorpoet
Bro, Spirals with the Symbio foam are ACEFinal e and symbio w peeled?
I liked the symbio with foam more then the peeled ones
glad you like it I’m happy with this combo too sounds awesomeBro, Spirals with the Symbio foam are ACE
Wait, how does that work? Remove foam from symbios and stick in the spiral dots?glad you like it I’m happy with this combo too sounds awesome
Yes , be careful . Best tipsWait, how does that work? Remove foam from symbios and stick in the spiral dots?
The wait is really painful. Go for ciem send them impressions on April. Took 19 days for ear molds to Linsoul. 4 Day from USA to CH and it stuck at customs for 15 days.
The turn around time for fearless is very quick though. Once they got ear molds just about one week and they send it back.
Got the package from DHL (very fast) .. turn out its wrong color and the fit is kind of loose. Talked to friend and all of them suggested to do refit. ... go to audiologist again to make another set of ear molds (2 pairs this time). Send it back to Linsoul on 5th June. 5 days later the package arrive to China. Again stuck at customs .. and still stuck at customs till this day. Now it's one month since I send it back to refit. Can't believe the package still stuck at customs for 23 days.
Just warning if some one want to go for ciem and have to send ear molds to them. The wait time for China customs is really bad.
Yeah, used the bite block but they told me to bite it after they put silicon into my ears. So, it might because of that.
So, this time. I bite the block before they inject silicone. Hope the fit will be great this time.
Anyway ... still waiting my package to clear China customs ....
Thanks, can one make this hybrid tip using JVC spiral dot + Comply foam tips?
