Brainiac9000
Hi, do you all know which comply tips or spinfit tips compatible with fa7?
CP100 will fit snugly and the CP145 will fit comfortably.
Nozzle diameter 5.15-5.65 mm. For Comply, I’d go 600-series M, or 500-series S.Hi, do you all know which comply tips or spinfit tips compatible with fa7?
Included M Bass tips are working for me.
Do the included M foam tips fit you?
Sony IER M7 is better tuned, FA7 is better spec wise.anyone able to make a comparison between this FA7 and the Sony M7? both have similar config of quad BA's but one is almost twice the price
Too bad they don't sell cp145 in my nearby shop. They only sell cp100.CP145 gotta be the most bloomy tips there is, not sure if they're a good choice here.
Thanks for your impressions, although having heard both FA7 and FH5 I don’t at all agree with your findings. I find the FH5 bass far superior to the flat and rather boomy FA7 bass, which tends to be more mid-bass focused with less rumble and weight. Guess it’s a matter of preference, and the type of music you listen to, but in almost all cases I prefer the FH5 to the FA7.Sony IER M7 is better tuned, FA7 is better spec wise.
Sony IER M7 is pure full range Sony driver. It has better mids and treble is touch more smoother and resolving, never sibilant. The mids tuning make it expansive. FA7 is faster, much faster detailed and bass extended. This makes them better at transient response. One of the fastest attacking bass(rank second to 64audio u18t). I think they crossed CI lower than many brands, making it focus more on lower side of bass and then getting the ED to do mid bass and mids, thus making ED do less 2kHz overall. And then passing SWFK for pure treble purpose.
CI does somewhat better job on faster bass on pure woofer design.
I mean, it is league above in speed compared to FH5 in bass department.
Sony M7 is more coherent(fiio is also, but sony has a different charm here). Sony gives better image to grand piano and the ambience. Fiio does air and the room acoustics better. Sony midrange and treble let you monitor in studio in mixing. Fiio is for music producers to detect faults.
Sony-mixing
Fiio-finding faults.
Both should be given FLAC as mp3 dont do justice.
FH5 for mp3
I meant to say, fiio fh5 do justice with poor recording compared to FA7.Thanks for your impressions, although having heard both FA7 and FH5 I don’t at all agree with your findings. I find the FH5 bass far superior to the flat and rather boomy FA7 bass, which tends to be more mid-bass focused with less rumble and weight. Guess it’s a matter of preference, and the type of music you listen to, but in almost all cases I prefer the FH5 to the FA7.
Here’s where I’m at in the present. M Bass tips, probably average-to-less-than-average insertion depth.
Do the HODVTEC go that low? That said, I wonder how the FH7 (with a DD handling the low end) is fairing in FiiO's alpha testing? It seems that one hasn't surfaced for public eval quite yet, even though they've been talking about a March domestic release.But if they have used a extremely damped vent open HODVTEC instead of CI, the bass could had destroyed the FH5, Sony Z5 though
Sure! I'm just cropping an EarStudio app screen shot on my iPhone. Please share.After having listened to the FA7 more with my initial tweaks from the ES-100, I like it more and more. For my settings, I wanted the same stock bass, but a bit more emphasis on the higher end of the spectrum to lift the vocal veiling. This is more of a fun EQ and less technical/ reference.
Mhoopes- I have a favor to ask. If I give you my ES-100 EQ settings, can you run a graph using your FA7 and my settings? I am just curious to see how my settings look on the spectrum and provide a baseline. I understand if you don’t want to. Thanks!!
Just raising the levels above the mid-bass isn't too different from just lowering the mid-bass. It's about their relative levels. I also found that a little extra emphasis in the pinna-gain range for DF (2-3K) helped with the balance. I found that the Headphone Collector had the same basic impressions.
Yup you are rightDo the HODVTEC go that low? That said, I wonder how the FH7 (with a DD handling the low end) is fairing in FiiO's alpha testing? It seems that one hasn't surfaced for public eval quite yet, even though they've been talking about a March domestic release.
My experience with the FA7 is telling with respect to the mastering techniques of the recorded material. I'm not finding a lack of sub-bass in more modern jazz recordings, for instance, with the FA7. If I'm interpreting your statements correctly, you're saying that the slower decay of a DD passes noticeably more sub-bass energy than the BA, and that's a major factor. I'm also thinking that perhaps a lot of older recordings literally contain less sub-bass energy, but were mastered with "slower" studio monitor drivers closer to their contemporary mainstream reproduction chains.
In your experience, are DD bass harmonic distortion products (that can produce the "missing fundamental" perceptual effect) also a factor in sub-bass perception, as compared to BA, or is BA harmonic distortion equivalent to DD in that range?
