Is a coloured dongle like the ru-6 better for the ie600 or a more neutral one like the moondrop dawn pro? And is the ie600 the best smaller sized iem?
Exceptional in Every Detail: Say Hello to the IE 600
- Thread starter Sennheiser
German Expat in Vietnam
Hello everyone, I was actually 100% sure about buying the IE 600. But after reading the entire 149 pages, I have doubts. For the following reason: I have the Sony AM 2. Two users wrote that the Sony AM 2 does not have a good synergy with the IE 600. An AM 2 owner wrote that it was fantastic with the AM 2. However, he only heard metal!!! I actually listen to everything except metal. Could someone who also has the combination tell me how it fits together? Thanks in advance !!!
Can nobody tell me anything about the combination of Sony AM 2 and IE 600???
Simon Patten
I would say a more neutral one as the IE600 has a fairly U shaped sound.Is a coloured dongle like the ru-6 better for the ie600 or a more neutral one like the moondrop dawn pro?
Many people seem to think so, it's the best I've heard and very comfortable.And is the ie600 the best smaller sized iem?
Which ones do you like better and how does it sound?Currently undergoing trials....Pentaconn vs Azla
Just got my ie600 in a few days ago. Have been curious about this set since it came out. Will be comparing directly to the Final A8000 the next few weeks.
rlw6534
Oh well, I just sent mine back for RMA. The left earpiece dropped out for me a week or so ago, cable and eartip changes didn't fix it. Oddly it started working again the next day but now I have channel imbalance with the left significantly louder than the right. Seems odd, but it is what it is.
Mine were from the first preorder batch, direct from Sennheiser.
@Sennheiser
I haven't heard anything about my RMA. Should I have gotten an email or something by now?
If anyone is interested I did get RMA replacement IE 600s in the mail today. They appear to be totally new in a sealed box. No complaints on that obviously.
Note that I never received any communication at all, which could have been better IMO.
I mailed them back on Jan 4, so turnaround was quite reasonable.
I just tried the Penon Liqueur tips with a short spacer at the base of the nozzle on the IE600 as mentioned in some past posts. The liqueur have a small flange that locks in behind the flange on the nozzle of the IE600 so they stay put on the nozzle very well even when spaced well out to the end of the nozzle.
The XL size has a larger diameter than most L and that combined with the sticky texture makes for an excellent seal that stays put nicely despite the somewhat shallow insertion depth that I get with the IE600.
With the good seal they sound as good at the Divinus Velvet that were my previous favourites.
Your milage may vary since on some other IEM the Liqueur don't work well being difficult to fit due to the sticky texture, must be a combination of ear anatomy, insertion depth and angle I guess.
https://penonaudio.com/Penon-Liqueur-Silicone-Eartips.html
Waddiewadkins
Is their largest bigger than the divinus largest?I just tried the Penon Liqueur tips with a short spacer at the base of the nozzle on the IE600 as mentioned in some past posts. The liqueur have a small flange that locks in behind the flange on the nozzle of the IE600 so they stay put on the nozzle very well even when spaced well out to the end of the nozzle.
Yes, much.
The XL Liqueur is 15.5mm while the Velvet L (the biggest they do) is 14.2mm.
That makes a big difference and the sticky texture it helps even more to keep them in place.
Second best part is they are cheap as chips at $9.90 for three set of whatever combination of size you want, delivered !
Waddiewadkins
K. I'll go with these first. Seal for daysYes, much.
brazy001
- May 25, 2013
Gu craftsman cable with ie600. Chose it for the complimentary colours of the mmcx connectors and the mottled cable colour which also compliments the shells and reminds me of snake skin.
I wish these connectors were on the tripowin mirage instead on the chrome caps. Oh well, one cable in 3.5 and one 4.4 will have things covered.
Do you guys like a deep or shallow insertion for this IEM?
Anouk
- Jul 8, 2008
Hi everyone ie600 and ru6 will probbably be my next portable stack. A bit worried about the stock eartips though. Did see a lot of people having luck with spinfit/spiraldot++. Any other recommendations?
PeacockObscura
Divinis velvets work really well for meHi everyone ie600 and ru6 will probbably be my next portable stack. A bit worried about the stock eartips though. Did see a lot of people having luck with spinfit/spiraldot++. Any other recommendations?
Total: 9 (members: 1, guests: 8)
