Nov 6, 2023 at 10:15 AM Post #1,951 of 2,599
Is there a fool proof way of detecting the fakes? I would need to buy from the used market because of the cost.
The issue of fakes is the only thing holding me back.
There isn't a sure-fire way to tell, unfortunately. Note that new ones are currently on sale for $599 from several authorized dealers.
Nov 6, 2023 at 10:22 AM Post #1,952 of 2,599
Thanks for reply. I'm in uk & have budget of approx. £400. Used examples are available in this price range.
I'm surprised that @Sennheiser has not addressed this with some official guidance. For me, the lack of clarity has killed my interest in their "ie" range.
Nov 6, 2023 at 11:09 AM Post #1,953 of 2,599
Ah but clarity really is the thing with ie600 hoho you knew that was coming
Nov 6, 2023 at 3:46 PM Post #1,955 of 2,599
Nov 6, 2023 at 4:00 PM Post #1,956 of 2,599
Nov 13, 2023 at 1:57 AM Post #1,958 of 2,599
Helloo! I'm thinking of buying the IE600 ,however I have read IE Series have QC issues is that true any idea ? thanks for any help
The stock IE600 cable is really trash, loses signal when cables move at certain angles, sticky, tangles... suggest you replace them anyways. I doubt the drivers have QC issues so if you can budget in a set of cables i think all's good.
Nov 13, 2023 at 4:08 AM Post #1,960 of 2,599
In my small audio community (~10 members), there are 5 IE600s, and 3/5 had driver issues for 1 side (totally dead, did not sound regardless of cables). Luckily, Sennheiser offers 2 years warranty so all of them have been replaced for the new ones. But, it raises a big question about QC, QA of Sennheiser to me :(
Nov 13, 2023 at 8:45 AM Post #1,961 of 2,599
Just ordered FiiO KA2 after endless dithering on Go Blu because its pricey to me.. Cant beat a really well reviewed price to performance gadget to get you to actually buy it... Obv I have the balanced cable but I ordered the 4.4mm to 3.5mm adapter for my nice 10 buck ali epxress cable,, but I doubt the adapter actually turns it into an balanced cable?... Maybe I should just get the KA3...
Nov 13, 2023 at 12:44 PM Post #1,963 of 2,599
I picked up this cable for my pair. Let's me keep the cable attached to the IEM and just swap the end. It's a more tactile cable than the stock ones.
Janjunsi MMCX Upgrade Cable Replacement Cord Compatible with Sennheiser IE300 IE600 IE900 Headphone - 3 in 1 Audio Plug with 2.5mm/3.5mm/4.4mm Plug https://amzn.eu/d/j41jAwa
so a "balanced cable" isnt the whole thing its just the connection?
Nov 13, 2023 at 12:50 PM Post #1,964 of 2,599
Is it true that there are no power limitations since the Iphone 15 because uf USB-C?
Which dongle would you choose for IE600? I think Fiio KA13 or Cayin Ru7 is too strong for a single DD IEM like the IE600 which doesn't need a lot of power. Is a Moondrop Dawn Pro good enough or would you invest more? I think a weaker one is better because there are more refined volume steps and it doesn't drain the battery too much.
Nov 13, 2023 at 1:10 PM Post #1,965 of 2,599
I have a KA-3 which is plenty for me. I normally use it with my Sony Walkman, but occasionally hook them up to my iphone. (that is through a 12 pro and not a 15)
