davesa
- Dec 30, 2002
which model of ZMF cans? I have an Auteur and a Verite closed, as well as the Ether 2. The Ether 2 is light and very comfortable
It is an open headphone so you will hear sounds around you... can you control your listening environment? I listen to the Ether 2 for hours at a time easily.
Obviously the Ether 2 is planer, where the ZMF use a more traditional driver... all 3 sound amazing - the Auteur is a really fun headphone, where the Ether and Verite closed are more resolving. There are a LOT of pad choices for the ZMF that let you experiment with the sound and the cable on the ZMF is the same as the Audeze. The Ether 2 does have some more pad choices now as well - when I bought mine you only received one set of pads but now when you buy it you get three. One more set than you get when you buy ZMF.
The Ether 2 is easy to drive - I have driven it with Schiit Jot, Monoprice THX887, and my LTA tube amp and all perform well with it. It sounds really great on the LTA.
