andrewfiren
Can someone recommend me which cable can tighten Erlkonig's bass while maintaining the thickness of vocals?
You could try the new Ares S. I have the Phonix, said by VE to be the next evolution of Erlkonig, and that cable did what you are asking.Can someone recommend me which cable can tighten Erlkonig's bass while maintaining the thickness of vocals?
PW1950’s will provide that for you. A less expensive solution would be the cable that comes with the LE version which is also excellent. It is all silver and sounds great. You might want to ask VE who made that cable for them.Can someone recommend me which cable can tighten Erlkonig's bass while maintaining the thickness of vocals?
I forgot this was the Effect Audio Thread. Leo II should also provide what you are looking for, but not sure it will sound better than the cable that came with the LE version of the Erlk. I have never used it on my Erlk.PW1950’s will provide that for you. A less expensive solution would be the cable that comes with the LE version which is also excellent. It is all silver and sounds great. You might want to ask VE who made that cable for them.
Give a try of Cleo II and Cleo II octa at our Booth in HK AV show, if you happen to pop by. The pairing is great with both EK and Phonix to have a sonic improvement base on its original sound signature.Can someone recommend me which cable can tighten Erlkonig's bass while maintaining the thickness of vocals?
Stay updated on Effect Audio at their sponsor profile on Head-Fi.
Just got my Eros S and realised there's no strain relief out of the plug.. thought was just mine but yeah I see your pics to not have them either. All my other cables have it, which is strange and worrisome cos there is some sharp edges to the plug and I have to see how this affects durability in the long run.
If you're worried about it being ugly, I think it's worth remembering that we're talking about Effect Audio here.
I had tried Ares II before, and find the bass is too much for me! Haven't tried Ares S though!You could try the new Ares S. I have the Phonix, said by VE to be the next evolution of Erlkonig, and that cable did what you are asking.
How about Code 51?I forgot this was the Effect Audio Thread. Leo II should also provide what you are looking for, but not sure it will sound better than the cable that came with the LE version of the Erlk. I have never used it on my Erlk.
I have planned to go there on the first day of the show this coming Friday! Thanks for your suggestion, I'll give it a try!Give a try of Cleo II and Cleo II octa at our Booth in HK AV show, if you happen to pop by. The pairing is great with both EK and Phonix to have a sonic improvement base on its original sound signature.
Suyang
Ah, okay I gotcha.
