Did you unzip the file from iBasso?
There are some directions on the first post of this thread.
Its easy to get it wrong
yes downloaded from ibasso website and followed the directions in the readme txt
You should put to DX200 not the zip archive you've downloaded, but a zip archive from inside the first one.yes downloaded from ibasso website and followed the directions in the readme txt
Is there a link to this carry case or is this DIY?
It is the Elephant Elite EL008 with Pre-Cubed Foam:
https://www.amazon.com/gp/product/B0186FN250/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
I have two of them more:
One with my Lotto Paw Gold and 64 Audio U10:
And the other one with my AK380 and Rhapsodio Solar custom:
Well I know what my next Amazon purchase will be
I'd personally also like to see a touchscreen controlled volume aside from the physical pot.
I wonder when will the official firmware support USB out (to external dac/amp devices)?
Ah you mean turning the volume pot dial first to pop up the volume slide? Yep that is in Android mode. I should have clarified I spend 99% of my time in Mango mode (and go to Android mode only to upgrade my firmware).Think there is a volume bar if you pull down from top of screen iirc
