DX200=Affordable High End Audio. Dual ES9028Pro dacs. AMP1, AMP3, AMP5, AMP7 & AMP8 ***Firmware support now up for AMP9***
Mar 29, 2018 at 4:37 PM Post #12,091 of 22,021
Please help step by step
For step-by-step instruction I need to know which Windows version do you use and nave such a version installed in English, because neither screen shots in Russian, nor back translation, won't help. I'm currently running Windows XP, and I'm sure you are not. So please try to find somewhere else how to launch Device Manager, find the "Unknown device" there, double click it, open "Details" tab and find "Hardware ids" there. I.e. that's what I've already told you, and, you see, I can't tell you more.
Mar 29, 2018 at 4:52 PM Post #12,092 of 22,021
Here is what I found after your instruction. So what is the next step?
Mar 29, 2018 at 5:13 PM Post #12,093 of 22,021
These are correct VID/PID for a RockChip device in a mode suitable for flashing. It means, your device is good, but you have no drivers installed.
Read the instruction provided with FactoryTool and follow it to install the driver and then use FactoryTool. Nothing new :)
Mar 29, 2018 at 5:25 PM Post #12,094 of 22,021
All working with Tidal, thanks for the help folks
Mar 29, 2018 at 6:09 PM Post #12,095 of 22,021
I got the Astell and Kern XB10 Bluetooth headphone amplifier recently. It sounds pretty good. It supports Apt-X HD. Since the DX200 has Bluetooth 4.0, are there plans to add Apt-X support to it?
Mar 29, 2018 at 6:51 PM Post #12,096 of 22,021
sorry to ask what is the dx200 Cu as I do not see it on ibasso site
and does it differ than the regular dx200 sound wise
Mar 29, 2018 at 8:04 PM Post #12,097 of 22,021
I GOT IT. Thank you.
Now if I want to get UAPP do I need to install a different Lurker FW which uses for UAPP only?
Mar 30, 2018 at 1:39 AM Post #12,099 of 22,021
On my XP machine, it showed as usb device rather than unknown device but everything worked just fine updating to the Lurker firmware.
Mar 30, 2018 at 3:48 AM Post #12,104 of 22,021
